mshabaz
- Aug 16, 2006
Running noise front track area on decel or compressing suspension. Not sure where it's coming from.
stingray719
Known issue, lower front skid mount to lower holes, back to center holes
mshabaz
- Aug 16, 2006
Put in lower holes? Mine are in center hole now
stingray719
Where your feet are, that bolt on both sides in the top hole or bottom?
mshabaz
- Aug 16, 2006
It's in the top hole
stingray719
Move that one to the bottom hole. Or ask your dealer to move it
mshabaz
- Aug 16, 2006
I can easily do that. So I can just assume it's a slight clearance issue.
stingray719
Seems all the 2016 XTX LE have it, some say theirs came with bolt in bottom hole and some do not. Inrbigness had it happen on Thanksgiving weekend and he fixed it moving the bolt down. He may respond here if he sees it.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Yep. Known issue. Lower the skid to the bottom holes on tithe front and the middle ones on the back. Let air out of shocks, support the rear. Undo rear ones first then undo the front ones. Slide down, attach front bolts then tears. Refill shocks filing evol chambers first put sled down.
This fixes the issue. It not only moves it down but also back about 1/2 inch.
