Dogrunner
- Jan 5, 2017
- Montana
- 2003 RX-1
Has anyone replaced running boards with a different style or added a grip strip on the outside edge? I wear whites elk hunter pacs because of the support but my feet slip often when I push down on the running board to help with direction change. thank you!
radianguy
- Jan 1, 2007
What sled do you have?
There are many choice out there for board upgrades, but need to know what you have before can offer any suggestions.
Dogrunner
- Jan 5, 2017
- Montana
- 2003 RX-1
03 rx1
radianguy
- Jan 1, 2007
Not much you can do, heat exchangers riveted to your boards. You could add traction screws to outside edge of running board.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
I would try to find a old set of Rox SledTreads. They also had a Flare Kit available.
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
I always thought of fabricating running boards that had the coolant run inside the outside edge of the running board. That way the rx1s and apexs could have a snow free running board.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
there are some old posts of guys rolling out the edge rolls and adding other brand (A/C I think) grip edges (very aggressive for the time). The end result was very nice.
Dogrunner
- Jan 5, 2017
- Montana
- 2003 RX-1
That was Betheviper on the 2 smoke side I believe. Very nice work and write up about the modthere are some old posts of guys rolling out the edge rolls and adding other brand (A/C I think) grip edges (very aggressive for the time). The end result was very nice.
You can. There are aftermarket grip strips that you can install on the outside edge of the boards as well as insert for the boards themselves.View attachment 125447 Why can't a guy put these on? There are lots of rivet tabs on the heat exchangers and about half are not even used so what if a guy has to tig a couple small pieces on the boards for a exchanger mount?
Google is your friend.
Dogrunner
- Jan 5, 2017
- Montana
- 2003 RX-1
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Don't drill into your coolers or the job will get a lot more interesting LOL
One issue with agressive boards over the stock ones is that the snow doesn't fall out. You end up with even thicker slabs of ice that can cover your added traction.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
The real answer is to move the coolers, but yes this gets expensive.
