redtailshark2000
I took my sled for a ride last night and all was well. Went across the lake to do some fishing and all that. On the way home when I put the throttle to the bar on the straights, the rpms would got to 10000 and kind of cut out, go up, and cut out again over and over. Made the sled feel like I was running over bumps but it wasn't. It was like it was skipping. It idled and cruised nicely, but when I gave it the squeeze I had these problems. Mods are K&N's and Bender exhaust. Any ideas?
K&N filters got a little wet and froze choking engine at full throttle.
redtailshark2000
fix
Would remedy would you suggest? Warm them up?
It would be the first thing to check and see if thats the problem if not then look else where.
Re: fix
Take them off, dry them, put them back on and see how it runs.
redtailshark2000 said:Would remedy would you suggest? Warm them up?
redtailshark2000
UPDATE!
I figured it out! Track was way loose after riding the super rough ice chunk lake (thanks to people who like to ride when it's raining). The drivers were slipping because it was too loose, when i would accelerate too hard they would slip.
LOL OK never thought of that glad you got it worked out.
