rapidroy5858
Seems like carbs need cleaning ..any tips? a friend told me to remove orings in float bowls where it slides over jets? Do they need to be synched?
rxrider said:Check the throttle cable free play, to tight cable may trigger the TORS system.
It's supposed to be 2-3 millimeter gap (free play) at the throttle lever.
While cleaning the carbs adjust the pilot air screw at the bottom of the carbs to 2 turns out from lightly seated.
Inspect the rubber diaphrams on top of the slides for cracks.
Make sure the small o-rings underneat the carb cap goes back, easy to loose them when taking the carb caps off.
Check the vacuum signal lines going from the carbs to the fuel pumps.
Make sure you have fresh fuel.
Inspect or change the plugs.[/
Better than text book advise.... Can't loose following this advise.
