Screwed Up Breather Hose On Attak! Check Yours
Slush Monster
Snow belt WI.
Hey... Found a breather hose that was kinked off and not installed right on my Attak. The hose is the short left rear breather hose on the airbox as your looking forward. It is a somewhat hard hose to put on and dealer missed it. You guys may want to check out your sleds. Also the skis were WAY WAY out of alignment. 1" past spec. . Other than 2 scratches on the windshield from them installing the (hood) and them caving in one side of the blastic belly with there missadjusted sled dolly everything is great. Starting up that 150 made me forget these things. WOW!! COOL!! . I fixed these things up and she is ready to go. :Rockon:
Thanks Slush
Sounds like some sloppy dealer set-up, that is unfortunate. I would do yourself a favor and check all the nuts and bolts, especially the shocks and skis (dealer installed). Good luck!
I very carefully went over the sled. Every thing else was fine. I did find that there was 0 grease in the front outside a arm pivots-dry as a bone. I thought about putting grease fittings on them but not sure.
