POWERHAULIC
By my measurements offset is at 59.2 using Daves bar.
Of course i need to machine 2-3mm to get there and still have a shim.
I am at 60.2 no shim, good enough for what is left of riding here.
My bushing has a bit of play, no more than new tho
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I took a quick look through the service manual for a spec but didn’t find anything yet so haven’t measured mine. Don’t know that this is a problem or not.
When driven is bolted together, it should work smoothly with no excess slop. If the bushing is too tight on the shaft it will bind when warm.
The sheave will seem sloppy when not all bolted up as an assembly with the helix bolted down properly. It's normal to have a fair bit of wobble with just the single movable on its own.
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Thanks Mike.
RX1Jim
Can someone who has the Hurricane alignment tool please post instructions or a video on how to use the tool? I'd like to understand how it works before I buy one from Dave. Many Thanks!
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
Lonerider
- Feb 26, 2010
- south west mi
- 04 rx1, 05 Warrior 06 Attak-w/yamacharger, 07 Attak-Supercharged, 17 Sidewinder TD power trail
I had my secondary shaft cut down to 50mm and did not cut the aluminum plug that holds the secondary on. Basically had a floating secondary. Then tried it cutting the plug down to 43.2 mm making it a fixed sheeve. By cutting down the plug it was much better. Never blew a belt after cutting down the plug. I put on 960 miles last weekend. Trying it both ways. I do not think just milling off the secondary shaft does the trick. Take the same amount off the plug as the shaft in my opinion.
Lonerider
- Feb 26, 2010
- south west mi
I have a hurricane tool and with in .5 mm now.
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
And what does your offset measure now?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Mine now is about same as Jims....
I had my guy make up some custom size shims, so Ill aim for 59mm.
So has anyone thought or tried to put a float into system like we used to have?
Meaning, can we not go back to utilizing the 3 holes,bolts,washers for deflection old school. Not sure if this is something that would even matter?
Dan
Dan
POWERHAULIC
Once the clutches start to shift we have float Dan.Mine now is about same as Jims....
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yep I know that. I was talking about the old way, check what I wrote closer.Once the clutches start to shift we have float Dan.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
cutting the plug or just removing washers...seems to me that be the same
