XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I have 1700 miles on my original belt. Every time I take my sled over the C note I wait for it to blow because of all the belt issues I keep reading about.
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Stock. I've tried 70 degrees, tried shimming the helix for coil bind, aftermarket springs & helixes, etc.What is the secondary set at? I had to crank mine up 10 degrees from stock or it would slip the belts real bad and they would blow at about 400 miles. Now I just change them around 1200 miles and they don't look bad.
krm
- Apr 22, 2016
- ny
Is it snapping the belts ,or is the belt in little pieces ?Snapping the belt is alignment ,belt pieces is heat from the clutching ,or improper adjustment ./Try running it Slow on the jack stand with no shim and the bolt loose to see where the driven ends up .
Soupy
- Jan 10, 2017
- West Michigan
The ultimax I tried was little pcs but most of them look like this picIs it snapping the belts ,or is the belt in little pieces ?Snapping the belt is alignment ,belt pieces is heat from the clutching ,or improper adjustment ./Try running it Slow on the jack stand with no shim and the bolt loose to see where the driven ends up .
Soupy
- Jan 10, 2017
- West Michigan
Another pic
Soupy
- Jan 10, 2017
- West Michigan
Pic
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Shredding/belt disintegration is caused by heat, clutch alignment or broken springs. snapping belts is usually a binding issue or bottoming out the belt in the secondary.
I would put money on it that it’s an alignment issue seeing that he has had everything apart and changed all the springs and weights. Still blew belts.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea that’s heat damage
Soupy
- Jan 10, 2017
- West Michigan
Clutches have always been way too hot to touch.Yea that’s heat damage
Fleecer
- Jun 13, 2014
- 2019 SRX
Just curious...are you running a cold air intake?
Soupy
- Jan 10, 2017
- West Michigan
NegativeJust curious...are you running a cold air intake?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I think these engines are solidly mounted, and should not have variances from one sled to the next.
But when you see several threads for two yrs now of belt blowers, it does bring into question....are there some sleds out there with something off in the mount location, making things out of alignment enough that you get extreme heat.
It sure would be nice to figure this stuff out so we can all check for whatever is the issue.
Please keep us posted, but it sure is gonna take a good tech to figure this out...most dealers many times dont have enough money to pay for a top notch tech unfortunately.
Dan
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Literally takes 10 minutes to check.
See my post in this link
https://ty4stroke.com/threads/clutch-offset-stms-and-stock.150838/page-4#post-1402850
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Dan
If you think they are all the same from the factory read this post. Super had to cut .125” from his clutch just to get it straight. STM secondarys are the same as stock secondarys. When I put mine on I had to change nothing from the stock secondary.
The 8 dn swap is easy and there are tons of posts here and the viper section it basically takes adding shim washers on the bolts on the back of the secondary sheave or buying an osp belt adjuster that mounts on the helix side of the secondaryThe 8DN is an apex belt. How can that be tried? Isn't it a lot shorter (or longer, I forgot without looking, but they aren't close)
8JP is the oem viper/sw belt
8DN is the oem most every other yammy
The 17641 number is the same on both so it must mean 'belt"...lol
- 13K
- 7K
- 31K
- 10K
