TC Rides
- Feb 1, 2019
- Wilmette, IL
- 2007 Yamaha Apex GT
Hey all,
I just brought home a new-to-me 2007 Apex GT, and need some advice. Obviously not riding until next season and hoped you all could point me to the service I should do to the sled. It is fairly clean with 8,100 miles. I live just north of Chicago, and have the sled at home. It will probably be kept in Eagle River, WI during the riding season. I can do most of the work myself, but don't want to do anything during the season except ride it.
I greatly appreciate your thoughts & suggestions.
The To-do list so far.....
Engine oil change & air filter clean
Chaincase oil
Spark plugs
Shock rebuild (sending them to Goodwin I think).
Repack all the idler wheel bearings
Install GPS mount & wiring
Front end bushings? (I don't know much about this)
Carbides probably
Exhaust donuts are starting to leak (obvious when running)
What am I missing?
Thanks a ton,
-Tim
Chaincase oil
Spark plugs
Carbides probably
What am I missing?
Thanks a ton,
-Tim
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Clean&inspect both clutches,replace antifreeze,check chaincase chain tension,regrease upper jackshaft bearing behind secondary clutch,regrease or replace driveshaft bearing (I would replace if history is unknown)front-end needs to be jacked in the air to check front-end bushings (look for excessive play)use clear spray grease on steering shaft bushings &shaft/ball socket ends.drain fuel system&run engine til out of fuel&then put in 1-10 gals non ethanol fuel&restart &run (unless already done)check slide wear&suspension bushings,check track tensionHey all,
Chaincase oil
Spark plugs
Carbides probably
What am I missing?
Thanks a ton,
-TimView attachment 148505
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Monitor that piece of aluminum that your flap is riveted to. It's obvious that the studs have done their job on the flap (which is no big deal)
But after a few years of ripping it up, the aluminum will tear up top. On my 07 with studs, I ended up drilling the rivets out of that piece of aluminum and replacing it. Then replacing the flap. It held it's distance from the studs and minimized further damage. You just don't want that metal ripping and flinging your flap down the trail into someone else. For now, you can bend it out to keep your flap out of the studs.
Good luck!
Good luck!
TC Rides
- Feb 1, 2019
- Wilmette, IL
BrotherDan & Biffdotorg, thanks a ton for your suggestions. Looking forward to getting into this project.
Does anyone have suggestions on where to source parts? Obviously, some parts are better OEM, but I am not constrained to working with only one vendor/ dealer.
Thanks again,
-Tim
Thanks again,
-Tim
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
going to depend on what part you need at the time. I would also suggest hid lights.
TC Rides
- Feb 1, 2019
- Wilmette, IL
Thor452, another good suggestion!! Its taking longer to find the parts and a good place to order them than it is to install them! if you have a link to a HID setup or bulbs and feeling like sharing, it would be appreciated !!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Get HID kit from Rock. He’s a member and a vender on TY. Great guy to do business with and always helpful. I believe his web site is yamaheaters.com.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Call Kevin at Port Yamaha for all your parts needs, great guy/dealer to work with.BrotherDan & Biffdotorg, thanks a ton for your suggestions. Looking forward to getting into this project.
Thanks again,
-Tim
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
If you are not against used parts, Barn of Parts has done great work for many of us. Very reasonable, and amazing collection of parts.
Good luck!
Good luck!
TC Rides
- Feb 1, 2019
- Wilmette, IL
Thor, Yamajon, 03RX1, Biff...
Good advice form everyone. I've started ordering normal wear & maint parts, and also have a set of Rocz's HIDs in the mail that should be arriving any day now!
Now if I could figure out some kind of stand I would be all set. I need to pull the shocks to send to Canondale, and get the front end apart to check bushings, etc. Also, gotta get exhaust donuts going and tune everything while I have it all apart (I would prefer not to have a "I should have replaced xxx while it was all apart" in November and take everything apart again.
Thanks again to all !!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Go with the copper exhaust doughnuts! Travis at BOP can help on that also.
