billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
1. Yamaheater w/boost (a must have)
2. K&N intake
3. Excell header
4. MPI silencer
5. 4" Bar Risers
6. PCIII fuel mapper (not sold on this yet)
*Need skis, & may need mtx heat-exchanger
2. K&N intake
3. Excell header
4. MPI silencer
5. 4" Bar Risers
1 1.75" Backcountry and extroverts.
2 MTX Skis.
3 Balljoint mod.
4 Revalve all shocks.
5 OFT Relocator.
2 MTX Skis.
3 Balljoint mod.
5 OFT Relocator.
Phyxius74
1. Curve XS skis
2. Excell exhaust
3. K&N Filters
4. Öhlins shocks
5. 146" extension
2. Excell exhaust
3. K&N Filters
4. Öhlins shocks
5. 146" extension
gormleyflyer2002
1/ Ohlins shocks on front / dual rate springs /
revalve rear
2/ Tall - firmer seat, tall windsheild
3/ Ball joint mod / Pilot skis / idler wheels
4/ Yamaheaters - thanks Rock
5/ Trail tank - blockoff plate
this is a great thread, i'm surprised that so many modify the exhaust system.
Cheers
revalve rear
Cheers
sofunkingcool
I just bought my 09 FX over the summer and so far this is what I have ordered and plan to start working on it today.
1) pilot Skis, with 7.5 inch Shapers
2) 4th Wheel kit
3) Extra wheels near Rear (already came with small ones in the front)
4) Tether switch/cord
5) Trunk bag
6)Billet fuel cap for some bling bling. lol
7) Busch aluminum Polish for that tunnel shine.
8) Skid plate
Im also looking into a clutch Kit prob. Ulmers and maybe a header and more studs, going to ride it first then make my decision. Also going to make my own Block off plate Thanks to you know who.
2) 4th Wheel kit
5) Trunk bag
8) Skid plate
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
1) Tunnel heat exchanger......gotta keep the engine cool
2) Roest skid plate......protect the engine and front exchanger
3) Subframe gussets......keep the skis pointing in the right direction
4) Trail Tank......theses things don't run very well on fumes
5) Skis/wear bars......no one likes a poor handling sled
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
As you can see, there is no shortage of must haves for this sled...many which should have been addressed by Yamaha, ie. skis, subframe reinforcement, hand warmers, larger idlers, etc.
Part of the fun though is adding all the extras that you personally feel you need (or afford) on your sled.
Have fun and welcome to the 4 stroke side.
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
one of the guys from the shop went down to a dealer meeting for sleds and yamaha now makes bigger wheels to cut down on hyfax wear
multi sled
yGrimm said:As you can see, there is no shortage of must haves for this sled...many which should have been addressed by Yamaha, ie. skis, subframe reinforcement, hand warmers, larger idlers, etc.
a yamaha shoulda of just did something like polaris did with the shift,bare bones sled cheap and let a guy customize it.
my list
1:simmons skis,if you don't do anything else change the skis
2:super Q exhaust
3:extended track
4:tunnel extension
5:clutch kit
6:z bros front end
7:team fast tri tek
on the burner, turbo kit,some billet stuff,air frame running board.
kizerboy
Here's the top five that I've done;
1. replace skis with ski-doo precisions.
2. powermadd pivot riser 3.25" total.
3. grease fittings on "A" arms.
4. marginal snow kit.
5. taller windshield.
larrypolaris
1. Hygear springs
2. Yamaheater hand warmers
3. Tall windshield
4. Trailtank
5. 6.9 Pilot skis
6. Ulmer clutch kit
7. Excell header
8. Skid plate
9. Ski Doo 135mm wheels
10. Ulmer Oilite bushings
3. Tall windshield
4. Trailtank
5. 6.9 Pilot skis
6. Ulmer clutch kit
7. Excell header
8. Skid plate
alsops
- Feb 17, 2009
- Headingley, Manitoba, Canada
- liverpool.com
- 2009 Nytro XTX
2021 Sidewinder XTX LE
top 5 so far
1. Remote start..a must here with -30+...you can set it to come on when at hotels etc and no garage!
2. HID lights...factory ones crap
3. Tall windshield w/ side deflecors
4. Hand guards with muffs
5. Rear storage bag set up
probably heated grip upgrade and spare belt holder where it should be!
2009 XTX
2009 XTX
yamakazie
Thanks guys! Seems like a good topic. Couple questions.
What skid plate are you using?
Is the windy that comes on the RTX a low or mid height? All I can find on the website is low and tall. I was hoping to go with the next step up.
This sled comes with the Fox Floats so are you talking about Hygear springs in the rear?
Thanks for the input!!
yamahahaha
1-skinz super-q
2-ulmer k&n intake
3-ulmer stage 2 clutch kit
4-powermadd 4.5" riser
5-144 studs (golddiggers r #*$&@)
2-ulmer k&n intake
LJ 452
Skid plate can be from Roest, Skins, or Yamaha. Either way get. Do a search and decide what route to go on that, as with many things on here a lot of opinions. The fact is anything is far better than nothing at all.
Hygear, they make springs for both the front shocks (Non-RTX) and the center shock in the rear suspension. The center shock spring I believe is a dual twisted, which will help with the stutters, but not be a sponge on the big stuff. Anything Hygear does is great, just be prepared for a bit of sticker shock, but it flat out works and they have a ton of testing to prove their product.
My top five add mods.
1. 128" extension with Hacksaw fully punched.
2. Curve's skis, great product, great company.
3. Ulmer front end bushings.
4. Spoke style wheels with replaceable bearings (haven't had to replace one yet).
5. Of course, skid plate, I went with the Yamaha, but the Roest was not out yet.
Of course I have done other things, but I would consider the above (with the exception of the extension and track) to be mandatory. I would do a lot of reading on here and spend the money fixing the shortfalls in the sled rather than make it faster or louder. The engine will last forever, plenty of time to make it faster. Unless of course money is no object, then buy everything.
- 9K
