**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I just repacked driveshaft and jackshaft bearings with amsoil grease....this exact grease recommended from a snowmobile shop...
http://www.amsoil.com/storefront/gwr.aspx
.....put the bearing in the freezer for easier reinstalling on the driveshaft.....
when I pulled the bearing out of the freezer...could hardly turn...
see the low temp torque spec..
now I will be changing to this grease...
http://www.amsoil.com/storefront/ghb.aspx
see the low temp torque spec...
based on my basic calculation...theres about 5 ft lbs of torque differential per bearing at -40....obviously less at higher temps...but imagine the possibilities!
Shane
- Dec 21, 2004
- Niskayuna, NY
- www.fa.ml.com
- 2014 YAMAHA VIPER LTX SE
2015 Ski-Doo 800 XRS Renegade
2012 Ski-Doo 600 ace
2010 Ski-Doo 600 e-tec GTX Limited
2007 Polaris Dragon 120
AMSOIL SERIES 2000 Racing Grease
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I think thats what i was using...what color is the grease?
ahicks
I used a moly based (disk brake quality) wheel bearing grease. FWIW
gonna use mobil 1 low temp -50 to 400f i believe.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
mobil 1 might be a good choice...no low temp torque specs...I've emailed them and will advise
RTXgary
Good point SJ, but I might be concered with the water washout numbers...9.2% I think I might try the AMSOIL Spray Grease. The torque is 1.3 but the water washout is only 1.6% check it out.
http://www.amsoil.com/storefront/glcspray.aspx
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
not only the torque for bearings....imagine the lack of suspension movement when it these greases require this much torque..
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
grease
here's what I will use..
for sealed bearings and skid..relatively low water wash with extreme low temp service.
http://www.amsoil.com/StoreFront/glb.aspx
linemech31
I would think that after a couple of miles the bearing would warm up and in turn would reduce the amount of torque required to move it.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
linemech31 said:I would think that after a couple of miles the bearing would warm up and in turn would reduce the amount of torque required to move it.
sure it would...to a degree...but my basic test was telling to me....even after warming conciderably it was still harder to turn...
the bigger point is in the skid...some of the half shafts have small amounts of movement...I think the skid will move far more freely ..
- 151K
- 10K
