pooner
Any one have their air shocks leak down? Mine were at 75 lbs and on leaked down to under 40 and the other was around 50. I noticed it looked like it was sitting lower to the ground. Hope this isn't an on going issue.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
I set mine after bringing it home and havent checked it since. I am 16 miles from teh 300 mile service, so I will check them then. How many miles on yours before they started leaking down?
Check the schrader valve. Wet your finger and stick it on it or better yet pump the shock up where you want it and put whole shock under water and see if it leaks. Look for bubbles.
stingray719
If you set them warm like above freezing then took it out where it is VERY cold they will do that. Just like throwing a raft on a cold stream....
Studroes144
stingray719 said:If you set them warm like above freezing then took it out where it is VERY cold they will do that. Just like throwing a raft on a cold stream....
Yes I have heard that temp does affect them. Talked with Ian from monster performance and he said that one of the viper he got to ride changed quite a lot from morning to night and then overnight aswell
pooner
I have 700 miles on it. I kinda figured that temperature would affect them. I did check them when it was warm. Been sitting in the trailer and we had some cold weather.(-20) Just something else to keep an eye on. Thanks
jedwards89
- Sep 8, 2008
- Tarrytown NY
- 2014 Yamaha Viper RTX SE
The floats naturally lose air and pressure should be checked before every ride. The temps also have something to do with it, but if you are going 700 miles before checking, I can guarantee they are not where you think they are. Having floats on my previous sled made it a habit to check them. I don't think you will see a huge difference in loss of pressure in a week, but if you are going 2,3 weeks before checking them you will see a significant loss.
