Sidewinder chain case bearings
Did anyone have any failures and if so, is there a good bearing upgrade option out there? I saw the part numbers are the same on 3 of the 4 bearings in the driveline when compared to the viper part numbers. The upper case bearing is the only one that is different from the viper but I also noticed it's even cheaper to replace. The viper upper case bearing is $12 and the sidewinder bearing is about $8. I can't imagine an $8 bearing is going to be good enough over time. I will be picking my sled up next week and I will pull it down and see what sizes they are and figure it out if someone hasn't already.
