**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
thats because your viper is not decompressed..making it more sensitive as you go up in boost compared to the sw
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Yes while you are completely correct, the hurricane viper 240 turbo kit spools faster then the 190hp kit due to cam timing adjustments that we make as the head shim is installed
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
wouldnt it require higher octane fuel than the 87 the stock winder could get away with (In a pinch) and have no protections like the winder?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Running alpha tubes(orange). Yes I used those wider clamps that cam with the Alpha tubes.. BUT The clamp (IMO) that's the issue is the one that comes right off turbo. Upper right side if standing over sled looking towards the rear of sled.. That clamp is tucked down in a bit. Its not wide enough IMOAre you running stock tubes? Mine are outfitted with Alpha tubes and CAI kit,and there clamps are realy rugged and you can tighten them with a lot of torque,no codes on mine yet,but we only have 635 miles,until todays end,maybe 750,by days end.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes it says upstream pressure But I believe your correct SJ.(I would say boost leak). Had the SD 26 a few times in the first 500 miles .. None since.. 2300 on nowboost abnormality is sd26 I believe
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I know, I was just replying to the fact someone said that there aftermarket kit had some serious lagthats because your viper is not decompressed..making it more sensitive as you go up in boost compared to the sw
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
edit
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Oh the CAI one,so far knowck on wood,we have not had an issue with any of the clamps on tubes,but did break one on header to turbo pipe.Running alpha tubes(orange). Yes I used those wider clamps that cam with the Alpha tubes.. BUT The clamp (IMO) that's the issue is the one that comes right off turbo. Upper right side if standing over sled looking towards the rear of sled.. That clamp is tucked down in a bit. Its not wide enough IMO
- 6K
