actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Looks great! Ordered the same rack and it came in today. How was the install?
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
just got word, the UNT linq double bracket shipped yesterday. will be doin the 40l trunk soon
actionjack
- Apr 9, 2005
Mechanical install is very straight forward. I had to create wire harness for lighting, mount lighting etc, plus I had to cut it since I wanted to keep the factory tool bag and touch up the finish.Looks great! Ordered the same rack and it came in today. How was the install?
Now to figure out first trip to ride.
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
What rack is that?
Sent from my iPhone using Tapatalk Pro
actionjack
- Apr 9, 2005
Up North Technologies Pro-Series 137-141 cut down to length to keep factory storage bag on tunnel.
http://upnorthtechnologies.com/pdf/pro_series_cargo_rack_yamaha.pdf
silverram323
- Mar 24, 2013
Thats very slick, easy install?
actionjack
- Apr 9, 2005
The install of just the rack is very easy. If use use the entire rack (remove factory storage bag) 6 bolts.
synaptic3e
What rear luggage are you going to buy for your sidewinder?
I guess I will need a small one for day trips and a bigger one for weekenders...damn it $$$
dgjr636
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
View attachment 124497 View attachment 124496 View attachment 124493 View attachment 124494 View attachment 124495
That is a nice set up but not the best to take in and off and is bulky.
I like the LinQ mounts many different combinations. Easy on and off and is easy to carry into hotel with ease.
I was able to find a nice bag to fit under LinQ accessories for spare belts and tools.
Some quick pics of my set up.
Ah good to see you covered up the doo logos
No issues with tunnel bend yet with the big gas caddy?
dgjr636
I used this similar set up on a 2014 viper with no issues. I put 3600 miles on it and current owner has over 6k now with same set up. 137 Winder tunnel is 2:1/2 inches shorter than 137 Viper so should not be a problem.
I think the BRP 3gal fuel caddy keeps the weight farther forward than most set ups. I also spray the under tunnel with silicone spray to keep the ice build up to a minamum.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Couple questions .View attachment 124497 View attachment 124496 View attachment 124493 View attachment 124494 View attachment 124495
How much did you trim off to fit the bag under ?
Is that the Yamaha rear wheel kit ?
What is your studding set up ?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Nice set up .View attachment 124492 Here is the bag I'm running... Tons of storage, but it's a bit bulky looking.
What is your studding ?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Looks great Don, nice job.
Dan
Dan
