DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I've got the 137 and I have whiteout technologies linq brackets, I put 500 hard miles on so far with no issues. I think its only the longer sleds that need to be aware.did you read about bent tunnels? just sayin so you don't find out the hard way....
yamahaex50
Anyone??Any thoughts on this powder keg? Evidently the 2.5 inch shorter tunnel really messed them up and this is the only one that will fit with the fuel now. Is that going to be too much for the tunnel?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I am speculating you will be fine. Others have run what seems to be as much weight without issue. Seems more issues are happening with BTX and longer (more leverage). If you are worried then Reinforce the tunnel. I am reinforcing my tunnel as a precaution due to Seat Jack install.
goby
- Jan 30, 2008
- Umeå
- Sweden
- 18 Titan Adventure 800
17 SideWinder BTX 153 LE
16 SR Viper MTX 153
16 SR Viper MTX 153
91 GLX Finlandia LTS
87 Skandic 377R
86 Skandic 377R
83 ET 340
LinQ bracket installed on one of the three 153" sleds. One more Viper MTX and a SW BTX will follow. Got the tow bumper on all sleds, I think it will keep the tunnel straight...
Got the 40L box for all sleds and the mix of stuff shown in the picture for one setup
yamahaex50
ThanksI am speculating you will be fine. Others have run what seems to be as much weight without issue. Seems more issues are happening with BTX and longer (more leverage). If you are worried then Reinforce the tunnel. I am reinforcing my tunnel as a precaution due to Seat Jack install.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Here's the Pro Series Modular Rack. Going to apply the LINQ adapter to this. This rack should add some rigidity (I did see the bent tunnel escapades, but I went for it anyway).
goby
- Jan 30, 2008
- Umeå
- Sweden
16 SR Viper MTX 153
16 SR Viper MTX 153
87 Skandic 377R
86 Skandic 377R
83 ET 340
Tom Eirik Andreassen
- Jan 19, 2016
- Mo i Rana
- Norway
- 2016 Yamaha SR Viper MTX 153'' LE McXpress Turbo
Have anyone tried the Yamaha shovel pack? The AC one uses cam locks to lock it in place, but on the picture, the Yamaha one uses the straps. Do the Yam one also use cam locks?
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
Cam lock is sketchy. Buddy lost bag and two new belts (mine and his) after trying to get those locks fastened down. It came loose multiple times and the last time lost bag altogether. Arctic Cat replaced the bag under warranty, but we each had to buy new belts. They were still in their plastic bags! Pissed off!Have anyone tried the Yamaha shovel pack? The AC one uses cam locks to lock it in place, but on the picture, the Yamaha one uses the straps. Do the Yam one also use cam locks?
yamahaex50
Have you had any issues with the tunnel with all this weight?So i have finally got the setup all connected.
UNT dual bracket
2 x 21L Bags
1 x 15L fuel caddy.
Everything fits and i was able to retain the tool bag!!
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
Shouldn't be a problem on a 137.Have you had any issues with the tunnel with all this weight?
dgjr636
No problems at all after 2400 miles with fuel caddy and bag full on LTX LE.
Many harsh trails also.
Offroadin
- Jan 17, 2015
- South of Ottawa
- 2017 Sidewinder LTX-LE,
Woody's/BOP/UNT/Sentinel guards&LED/LinQ
Not at all at around 1800KM. What a great setup!!! I only wish Yamaha had something similar.
yamahaex50
Sweet. Looking forward to hearing from your guy.View attachment 127065
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
I use these, sometimes I add a wp givi duffle bag over top!What rear luggage are you going to buy for your sidewinder?
I guess I will need a small one for day trips and a bigger one for weekenders...damn it $$$
25l each
