jeff catte
- May 31, 2020
- Saskatchewan
- 2015 viper xtx le, 2017 sidewinder mtx
Do all of the Sidewinder mtx 163 have their secondaries clocked at 3-1 stock? The 2017 service manual says it's 3-1. I'm trying to figure out where to try the Dalton orange spring. Other models are 3-3 so the 6-2 recommendation from Dalton is close to stock.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Set it according to Dalton's recommendation of 6-2.
jeff catte
- May 31, 2020
- Saskatchewan
Isn't Dalton's recommendation of 6-2 is for the sleds that come factory at 3-3? I'm just curious if all mountain sleds came clocked at 3-1 instead of 3-3 or if it changed after 2017.
- Apr 17, 2003
- Menno, SD
- Menno, SD
The mountain sleds stock spring is much better at 3-3 as well, it doesn't matter what the original spring setting was, you're replacing it with an aftermarket spring and it's suggested setting is 6-2.
iceback
Yes go with the aftermarket recommendation , 3 1 factory recommendation never worked all that great . If you do run the factory spring try 33 or higher .
jeff catte
- May 31, 2020
- Saskatchewan
Ok thanks. Just felt like my sled was reving higher. I have 1300km on it in the mountains with the factory at 3-1 and no belt issues and seemed to preform good. I'm hoping it doesn't run too hot.
