Woody255
A buddy just bought a new SW. On the first ride, he noticed a loud noise from the primary when he lets off the throttle. The primary cover appears to be slamming against the primary bolt washers(2) when the primary relaxes. The weights do not appear to be touching the rollers when shut off. Is it common to have to thick washers on the primary bolt on the Sidewinder?
Wingwong
- Mar 20, 2018
Do you have photos or videos
If it’s New it should be covered under warranty
The weights do not make contact with the rollers when shut off.A buddy just bought a new SW. On the first ride, he noticed a loud noise from the primary when he lets off the throttle. The primary cover appears to be slamming against the primary bolt washers(2) when the primary relaxes. The weights do not appear to be touching the rollers when shut off. Is it common to have to thick washers on the primary bolt on the Sidewinder?
Also, im guess that noise hes hearing is normal. Take a look
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Beautiful harmonics causing rattle, normal on this motor. You’ll be ok
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
I only notice the clutch noise at idle, it's nothing compared to the drone of the exhaust after a few hours.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I enjoy the sound. It's diesel like, but normal, and happens just before my helmet gets sucked off my head. Like a warning...lol!The weights do not make contact with the rollers when shut off.
I thin
I think the sound he is hearing is at the 34 second mark.Also, im guess that noise hes hearing is normal. Take a look
I agreeI thin
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Does your exhaust drone? My stock exhaust is whisper quiet. I can only hear wind noise above 35mph. If i give it the beans i can a little exhaust but nothing approaching the 4 cylinder. Its nice to not have ringing in my ears after a ride.I only notice the clutch noise at idle, it's nothing compared to the drone of the exhaust after a few hours.
Sorry, just noticed you have a different muffler.....
Chris Rose
- Jul 29, 2016
- Powassan ONT
I have the Turbo Dynamics SQ muffler. After a while it wears me down. Might have my original muffler modified .Does your exhaust drone? My stock exhaust is whisper quiet. I can only hear wind noise above 35mph. If i give it the beans i can a little exhaust but nothing approaching the 4 cylinder. Its nice to not have ringing in my ears after a ride.
theewarrior
Anyone trying pb 80 clutch?
Woody255
74Nitro, yes it’s much like the noise at the 34s mark, but to me it’s more of a metal on metal sound, and very sharp. It sounds worse than the video.
Hi Woody. It is metal on metal. That sound is made when the clutch returns to fully disengaged. The inside of the sliding sheave hits the spider.74Nitro, yes it’s much like the noise at the 34s mark, but to me it’s more of a metal on metal sound, and very sharp. It sounds worse than the video.
It's normal so don't worry about it.
If that's not it then I don't know what it is.
