![](/styles/vip.gif)
marc001
- Sep 28, 2013
- Howard City MI
- 2014 Yamaha Apex SE 2017 Yamaha SideWinder LTX LE
What is everyone seeing for sled temps. Mine goes to around 175 around the yard and then when i shut it off then turn the key back on its 215 degrees.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
That's normal. But any turbo machine avoid shutting off immediately after running hard. Let it idle for 1 minute at least... Let the Turbo and header cool down after running hard. Motor should stay under 210f when heat soaking.What is everyone seeing for sled temps. Mine goes to around 175 around the yard and then when i shut it off then turn the key back on its 215 degrees.
veemaks
W
Wasn't the Sidewinder designed so you didn't need to let it idle after riding? That is the information I have read in all communication from Yamaha.
![](/styles/TYLifeMember.gif)
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
W
Thats what we are told in the literature, but im sticking with my old ways of doing stuff. If i shut down one of our turbo diesel pieces of farm equipment without cooling her down my old man would, shove his boot somewhere no to pleasent. So old habits die hard. I like the idea of cooling the turbo down anyways.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Engineers have tested and decided it was safe to do so. However it is a 100% certainty that letting a header cool down a tad before shutting off is a good idea. You don't have to but it's better to do so.W
When engine runs coolant circulates. The header reaches temps of up to 1000F and transfers heat into the head. The head is a huge heat sink and it cools down the header. However shut off the engine and no coolant circulates.
The heat from the header can make coolant boil near the header side of the head. Letting sled idle for a bit gives a chance to the header to cool down and the cooling system from the sled to take the heat away and prevent coolant from reaching boiling point.
yellow rider
- Aug 4, 2014
- yamaha
Thanks for the tip. Good to know ! Probably not required if just trail riding.
