max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
yes it is, wrks greatis that a dalton spring?
JLR
- Dec 6, 2006
- Winnipeg, Mb
- 2011 apex mcx 290, 2018 sidewinder xtx se 137 precision stage 4, 2020 Sidewinder Srx
ok that is stiffer than the cat green are you running it same hole in secondary as before.yes it is, wrks great
Todd Beenen
- Feb 16, 2020
- Michigan
- 2020 T-Cat
I have the same secondary, with green spring, is it worth changing it to the new dalton, you notice the difference?
Todd Beenen
- Feb 16, 2020
- Michigan
- 2020 T-Cat
Black & Lime secondary spring?
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
It def wrks better, quickrr back shift hole 3 or 2
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
yea 0-9-0 up dwn retard spike, i just got back from a run of 100klm and when im at a sharp dwn hill on trail sled stumbles as if out of gas guage shows 1/3 tank or less, i have the return .... its ok on level but sudden stops or turns causes a stumble.
9 seconds long? or .9 long?
Are you zooming in enough on the log for that area? Can you post a pic of the log or PM it to me?
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
No it just spikes to 9 deg retard then back to zero in fraction of second
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
is it melting the wiring for the fuel pump? Have you upgraded to the heavier harness? https://boostkinetics.com/shop/ols/...0-998t-external-fuel-pump-harness-relay-turbo
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
Soo i took everything out of tank, replace the hose from top of pump to lid with fuel injection rubber none corrigated hose, put pump right to bottom of banana ,made sure all clamps on hoses were tight, pulled pick up feet out and fuel level sensor out ..soo i could make sure pick up feet are sitting flat. went riding yesterday for 100klm and found that riding very agressive into a corner and hitting brakes hard the sled would stumble uppon re applying throttle for a split secound or two.... whats causing this? its not the safety switch in throttle, feels like its fuel related or timing retarded.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I’d look at the throttle cable routing
I zip tied mine when installing an accessory cord cause it seemed like a good idea. I had the exact same stumble happening a couple times till I freed up the throttle cable
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
mine is completely free routed and i also loosened it up a bit soo cable had a small amount of free play. still stumbles on hard braking and cornering.I’d look at the throttle cable routing
Todd Beenen
- Feb 16, 2020
- Michigan
- 2020 T-Cat
Ben has no idea?mine is completely free routed and i also loosened it up a bit soo cable had a small amount of free play. still stumbles on hard braking and cornering.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
sent logs but havent heard back
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
still happening as described in the 3 gallons or less thread.
- 8K
