chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
Anger, despair, embarrassment.
Natural feelings when getting towed home, AGAIN.
Another upper gear failure.
First one, no holes, was at 2200 miles. Second one today, with holes, 1500 miles. My friend with 850 XRS is getting tired of towing me home and I am sick of getting towed.
Dealer just received 4 new replacement gears. One of their customers actually went through 3 gears.
THERE IS ABSOLUTELY NO EXCUSE FOR THESE FAILURES.
Its a gear, one of many in the same gearcase. Why is this one always failing?
Sidewinders should come standard with a tow rope and a huge warning label on it saying,
"DO NOT DRIVE ALONE".
I absolutely love the power and fun factor with my machine but it all goes away when getting towed.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Are you tuned? Are you running the chain tension to spec?
It seems like these are hit or miss. My dad has almost 7,000 miles on his top gear.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
What type chain lube you run?
How much?(oz.) and how high is the level in sight glass?
How tight is tensioner?
How much HP?
Dan
How much HP?
Dan
krm
- Apr 22, 2016
- ny
Run 4oz more of chain lube than is recommended ,I use the klotz with graphite in it .
Mototown
- Sep 11, 2018
- Apex 40 th
What kind of oil are using?
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
First gear was on stock tune, second was on tuned sled.
Mechanic sets tension. Its still on warranty.
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
Yamaha oil.
Half glass.
Mechanic sets it. I didn't remove muffler to check.
How much HP?
Hp is irrelevant. First gear was stock , 2200 miles second was flashed, 1500 miles.
Dan
Mike Belanger
- Sep 22, 2015
- Belle River , Ontario
- 2017 LTX-SE Sidewinder
I Have 2017 Sidewinder and has been tunes from the first day with 7500 miles....I have had no failure but will be taken a look at it this week to see.
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
Some are failing and some are not.
I wish I knew why. Dealer also wishes they knew why. All winter I was worried about getting towed home again. That's no fun.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Could it be the ones that are failing have an improperly aligned jackshaft/gears/axle? Remember back in the day when we "blueprinted" our chassis? Out came the squares with tracks off to improve efficiency in the driveline.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I concur on the looser chain as my top gear is like new after over 5000kms on 290 but also not convinced this is the only reason the gears are lasting.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Actually there is........ their mechanic is over tightening the chains.
I respect you man but you sure seem sure of yourself without enough testing in my opinion. Who knows maybe you didnt use reverse much this last check of bushing? I have said it before I have run mine both at spec of 1.5 out from finger tight and 1 turn out and wear was exactly the same. Never did check alignment of gears. that would make sense if off and explain the wear pattern also.Actually there is........ their mechanic is over tightening the chains.
marc001
- Sep 28, 2013
- Howard City MI
- 2014 Yamaha Apex SE 2017 Yamaha SideWinder LTX LE
What happens when the top gear goes out, does it pop out of gear or what?
- 6K
