KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Going by description it should be BW = hyvo: 1702-410 (OEM Arctic Cat Part SPROCKET,BW-21T REV-(13 WIDE/33 SPLINE)).
Now running 1702-490 (OEM Arctic Cat Part SPROCKET,BW-21T REV-(15W/33SPLN)OIL HOLE)
Lets hope the wider sprocket will last and take the power better without fretting like that.
If it continues, I'd be changing brands of oil or be doing something different there too.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yeah that is a 21 gear. So much pressure on it from 320 tune and lots of long studs the chain plates just dig into the gear teeth. Chain has a scissor action as it goes around gear. Running 38 bottom. 21/38 = 1.81
Scott Taylor has 25/45 = 1.80. I'd like to try this to see if there is less wear on 25 tooth top gear cuz it's bigger. Anyone know if there is a long enough chain for 25/45?
90 pitch should work
Turboflash
- Mar 18, 2019
- Southern MN
Ok thanks. Will try it.90 pitch should work
Turboflash
- Mar 18, 2019
- Southern MN
You were right (again. Are you ever wrong?It almost appears from the pic of the bad teeth on the gear that perhaps the chain is just too loose and barely making contact in the sprocket, either that or the oil just isn't good enough.
I've never had a gear look like that before.
Fits shaft nice and tight. 21/38 gear, 320 tune, 192 1.625" StudBoy Lake Racer studs.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
Question guys im gearing 24-50 i saw they make a 48 bottom gear 3/4” wide can i put a 3/4” instead of a 7/8” stock with the original chain? thks
Turboflash
- Mar 18, 2019
- Southern MN
Are you referring to 15 wide chain vs. 13 wide?
Stock 24 top gear is for 15 wide chain. Any narrower chain will not fit. Stock 50 lower gear is narrower than top. A 13 wide chain will fit that one but not 24 upper gear.
If you're buying a new 48 lower, then which one is it made for?
Stock gears an chain are hyvo profile. Silent chain and gears are not compatible and cannot be interchanged with hyvo.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
ok i will ré phrase i have a stock gearing and chain right now in my sidewinder witch is 24-50, how wide is the stock 50t gear 7/8” or 3/4” ?Are you referring to 15 wide chain vs. 13 wide?
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
ok so if i understand correctly the sidewinder stock bottom gearing is 3/4” wide?The Hyvo gears and chains are typically not advertised in dimensional width but in chain link width for ex 15. The silent chains and gears are typically advertised in dimensional width for ex 3/4".
As previously stated the 998s come with Hyvo gearsets and chains. Top gear is 15 wide hyvo, bottom gear is 13 wide hyvo, and the chain is 15 wide hyvo.
On my sled I run Scott Taylor hyvo gears and both top and bottom are 15 wide with a 15 wide hyvo chain. I have shimmed the top gear to align properly with the bottom gear so the chain runs true.
Correct. The bottom gear isn't as wide as the top gear.ok so if i understand correctly the sidewinder stock bottom gearing is 3/4” wide?
I have a 48 in mine.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
alright then thanks for the clarificationCorrect. The bottom gear isn't as wide as the top gear.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
and btw where do you bought it?Correct. The bottom gear isn't as wide as the top gear.
Cat dealer.and btw where do you bought it?
Turboflash
- Mar 18, 2019
- Southern MN
BTW - stock 92 pitch chain will be very loose on 24/48. Not sure if stock tensioner bolt is long enough. Not sure if a 90 (2602-840) would go on?
2602-364 is Cat number for 48T gear.
These are the gear combo and chain requirements I calculated for my SW.
Total top and bottom gear teeth_________/_____________Chain length
58-59______________________________ /_____________ 84 pin chain
62-63_____________________________ /_______________86
66-67_____________________________/_______________88
70-71_____________________________/______________ 90
74-75_____________________________/_______________92
So 24 + 48 gears = 72 which puts you in no mans land for chain length
I run 26/45 on my SW X-TX that has 8 x 3" drivers
26 + 45 = 71 and I needed a used 90 pin chain that was stretched a bit to get the combo installed.
These are my figures so confirm before you buy
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
24-48 would require 91 link chain on paper( 24+48= 72….72/2= 36+54.19= 90.19) and obviously theres no such thing so 92 will fit but be very loose. Never get a 90 on unless its stretched a ton. . When figuring links required you will come up with an ending of .19 or .69. For example 21-41 is 85.19 so 86 link chain. 22-41 is 85.69 so same 86 link chain will fit but numbers ending in .19 install easily and combos ending in .69 will fit but can be a pain in the #*$&@ to install the first time with new components. Once chain has mileage and has stretched it will install easier.
