@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
ok i will check fo that thksBTW - stock 92 pitch chain will be very loose on 24/48. Not sure if stock tensioner bolt is long enough. Not sure if a 90 (2602-840) would go on?
2602-364 is Cat number for 48T gear.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
54.1324-48 would require 91 link chain on paper( 24+48= 72….72/2= 36+54.19= 90.19) and obviously theres no such thing so 92 will fit but be very loose. Never get a 90 on unless its stretched a ton. . When figuring links required you will come up with an ending of .19 or .69. For example 21-41 is 85.19 so 86 link chain. 22-41 is 85.69 so same 86 link chain will fit but numbers ending in .19 install easily and combos ending in .69 will fit but can be a pain in the #*$&@ to install the first time with new components. Once chain has mileage and has stretched it will install easier.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
24/48 will not work .
As others have mentioned the 24/48 isn't a good fit. If I remember correctly I ended up with a 25 on top for better chain fitment.
There's better options.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
i think i will just remove a chain linkAs others have mentioned the 24/48 isn't a good fit. If I remember correctly I ended up with a 25 on top for better chain fitment.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Still won’t fiti think i will just remove a chain link
Turboflash
- Mar 18, 2019
- Southern MN
FWIW - Cat shows a 22/48 gear set for a 2013 XF800 (which is procross chassis). It's p/n 1702-331 which shows 90 pitch chain.
www.countrycat.com
Arctic Cat Gearing Kit 22-tooth x 48-tooth & 90-pitch Chain - 2013 XF 800
Arctic Cat Gearing Kit 22-tooth x 48-tooth & 90-pitch Chain 2013 XF 800 1702-331
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yes 22 not 24FWIW - Cat shows a 22/48 gear set for a 2013 XF800 (which is procross chassis). It's p/n 1702-331 which shows 90 pitch chain.
Arctic Cat Gearing Kit 22-tooth x 48-tooth & 90-pitch Chain 2013 XF 800 1702-331www.countrycat.com
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
23/46 same ratio and is 90 pit chain..... as 24/48 will not wrk
It does fit, I've done it, only briefly. Even with a new chain, the adjuster is only left with a couple threads left.
It isn't a good set up, and I don't recommend it.
Turboflash
- Mar 18, 2019
- Southern MN
Huge dog-leg!
