2022 sidewinder comes with a new upper shaft,,harder and new gear bushing,,,found this image.it s in french,but it says new upper and lower shaft hardness and new top bushing,(maybe steel bushing,because of harder shaft,or needle bearing).we experimented with needle bearing,and so far the best thing we found so far.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
2022 upper gear. The bushing APPEARS exactly the same as years past..
it supossed to be a new material.only time will tell.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Hope so.. Anything that's a effort to improve things is good.
Appeared to me the bushing was the exact same..
After chain stretches I'm going with a 22 DMC top gear, so I will never know if its different/better
we will know when the part number, is new.by the looks of it,it seems to be thinner coating,maybe a harder inner bushing.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Our dealer here in Vermont has been keying the inner race and the shaft so that the bearing cannot spin on the shaft. They tried it on my Dad's 2022 SRX and said the shaft is much harder than years past.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Can't really tell from looking, the bushing we use looks similar but is much tougher and fits the shaft properly.![]()
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yea looks are deceiving. I believe its more about the width/spreading the load over a wider area on the shaft then bushing material itself. Chain tension is a factor also.
. Will a better bushing help >yes.. Making it more gas n go.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
That's what some people want you to think anyways that a wider bushing is the only answer. Proper fit day one and a better material is really all that is required.
- 28K
