Even inspected the washer up against the cir-clip behind the top gear and there was zero sign of pressure there.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
My same experience on 280 & now 320 tune. 21T top gear bushing looks like new after about 2000 miles this winter on 320 tune. However, gear teeth faces look like there is severe pressure against them by the chain (and there is @ 320). Gonna need a new gear and chain every year. Bushing looks like new.
I’m speaking of this gear tooth pic, the wear is on the non drive side
No, that is the drive side.I’m speaking of this gear tooth pic, the wear is on the non drive side
These little sprockets suck especially with big power.
These type of chains don't like being wrapped around small diameters. Problem is that there is a lack of lower sprocket choices when running larger top sprockets to get the desired ratio.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
My bad it’s on the drive side, I was thinking backwardsMy same experience on 280 & now 320 tune. 21T top gear bushing looks like new after about 2000 miles this winter on 320 tune. However, gear teeth faces look like there is severe pressure against them by the chain (and there is @ 320). Gonna need a new gear and chain every year. Bushing looks like new.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I will say it seems like you have done everything correctly. Gear fretting is a sign of lubrication film breakdown. If you want to actually reduce chain torque switch to larger gears top and bottom. A larger gear on the top will reduce chain torque but increase its physical speed. Going to larger gears top and bottom will reduce stress on the components.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
It almost appears from the pic of the bad teeth on the gear that perhaps the chain is just too loose and barely making contact in the sprocket, either that or the oil just isn't good enough.
I've never had a gear look like that before.
Turboflash
- Mar 18, 2019
- Southern MN
Yeah that is a 21 gear. So much pressure on it from 320 tune and lots of long studs the chain plates just dig into the gear teeth. Chain has a scissor action as it goes around gear. Running 38 bottom. 21/38 = 1.81These little sprockets suck especially with big power.
Scott Taylor has 25/45 = 1.80. I'd like to try this to see if there is less wear on 25 tooth top gear cuz it's bigger. Anyone know if there is a long enough chain for 25/45?
Turboflash
- Mar 18, 2019
- Southern MN
Umm, well IDK . Been running 1.5 turns out, Amsoil Synthetic. This gear has 2500 miles on a combination of 280 & 320 tune.It almost appears from the pic of the bad teeth on the gear that perhaps the chain is just too loose and barely making contact in the sprocket, either that or the oil just isn't good enough.
Turboflash
- Mar 18, 2019
- Southern MN
BTW - this was a 13-wide gear I took out and replaced with a 15-wide one with oil holes. I'll be taking a look at it soon.
KnappAttack
- Feb 19, 2004
- Welch MN
Are you sure that 13 wide is a HYVO gear and not a silent chain gear? When did they use a 13 wide up top?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Well it sure looks like a hyvo gear, they have a round tooth at the crest. The vipers had 13 wide gears.
KnappAttack
- Feb 19, 2004
- Welch MN
It does look like a HYVO, but I had to ask.
Power does not eat gears up like that, something is not meshing properly from its appearance in that pic, or the lube is completely lacking.
Turboflash
- Mar 18, 2019
- Southern MN
Going by description it should be BW = hyvo: 1702-410 (OEM Arctic Cat Part SPROCKET,BW-21T REV-(13 WIDE/33 SPLINE)).Are you sure that 13 wide is a HYVO gear and not a silent chain gear? When did they use a 13 wide up top?
Now running 1702-490 (OEM Arctic Cat Part SPROCKET,BW-21T REV-(15W/33SPLN)OIL HOLE)
