Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
2019 Winder ltx-le blew main fuse while out riding lost power on everything. Reinstalled a new 30 amp fuse and reassembled Sled turn the key on and within two seconds blew that one as well.
After running a few diagnostic tests the voltage regulator was found to be faulty changed it and everything seem to be fine. Next right out proximately 10 miles out The ignition fuse 15 amp let’s go try to install a new 15 amp fuse key off reassemble Sled turn Key On and it blows. Trailer the Sled back to the shop and needed more fuses so Sled had time to cool down ran out picked up new 15 amp fuses and installed them and to my surprise it started and is running but I’ve lost confidence for now. Retested voltage regulator as well as stator But unsure of stator values for a 2019 winder ltx-le. As a sidenote I’ve checked on the fuse box and most of the wiring harness with no apparent short the grounds. Any help would be appreciated
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2014 Yamaha Viper XTX, hurricane 190 kit
2013 Yamaha Apex XTX
2017 Yamaha Sidewinder BTX
✂️ regulator testing
15 seconds · Clipped by Dan Johnson · Original video "FH020AA / FH012AA Mosfet Regulator Rectifier check out" by Roadstercycle
m.youtube.com
earthling
The stator readings on a winder should be between .2 and .24 ohms. Many multimeters will have problems with values that low so make sure you using a decent multimeter.
PSA: If you have a 23 winder without EPS there is most likely a spare 30amp fuse above the main relay. It is for the EPS normally but someone at Yamaha seems to be populating the fuse holder even when there is no EPS available. Think of it as a spare main... not the 'why did I opt out of EPS' reminder.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Check to make sure your wires below the fuse box aren't rubbing. It's a common problem. Sounds like you did this already.
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
Thanks guys for all the help as I continue to diagnose this issue, the metre I’m using is a fluke 179 and I’m getting .3 value the shop has an interior temperature of under 60
earthling
Thanks guys for all the help as I continue to diagnose this issue, the metre I’m using is a fluke 179 and I’m getting .3 value the shop has an interior temperature of under 60 may be the reason.
I disconnected the battery negative and hook the metre in line and to my surprise I was Pulling 10.5V.
To reduce this value I started pulling out the relays noting shift reverse dropped the voltage drain to near 0 discharge. This is really throwing me off.
10.5v? (not amps? from the way you described the connection is sounds like you are measuring current) Had a quick look at the schematic. The relays are designed as a simple logic gate to allow the ECU to flip the two wire circuit between forward and reverse. It appears that the ECU simply supplies ground to the relay it wants to deactivate, the power to the coil is from the shared 12v bus. The relays are wired NC by default and the ECU supplies the logic (pin 85) for which way current should flow by supplying ground, pulling the relay to ground (pin 87a) The motor itself is what controls current draw as it hits an internal limit switch and disengages for either direction.
Physical layout of the shift relays although I believe the relays are upside down relative to this drawing.
Schematic layout from yamaha. 85->86 should only be energized if the appropriate shifting mode is NOT- enabled (FWD/REV), the logic is opposite (ground means off).
I believe the machine comes up with the shift reverse relay (closed 30->87a) allowing it to act as ground for the motor while shift forward is in its default state (NC 30-87). When you select reverse the relays energize opposite (fwd closed, rev open) which allows the circuit to flip directions. Hope this helps.
Does reverse work?
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Make sure the inside of your power plug on the dash hasn't come apart too. Had this happen once but it only blew the dash and rear brake light fuse
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
Yes reverse works
I’m stumped lol.
What start it off as blowing my main fuse 30 amp from there found a voltage regulator had issues change that out replace the 30 amp fuse and I was good. Next outing 10 minutes into the ride it blew the ignition fuse 15 apmp blew the spare as soon as I put it in.
A few hours later Sled cool down replace the 15 amp fuse and it started right up and has ran ever since. Voltage regulator test fine stator Tess fine and no short to ground on the stator with no visible short to ground on wiring harness.
Disconnected negative battery terminal in and put tester in line in which shows voltage is this not considered to be a short?
I’m stumped lol.
Look in from above the primary clutch at the front left engine mount, frame portion. Had one just recently wear through.
earthling
Yes reverse works
I’m stumped lol.
Not sure what you were testing. Between negative terminal and what, and the negative battery cable?
Battery Negative -> Multimeter-> Battery Cable
like that?
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
Yes to see if there’s a draw
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
I’ve removed all the harness up to the handlebars with no visible signs of damage
earthling
Did you check under the fuse box? You will have to unbolt it.I’ve removed all the harness up to the handlebars with no visible signs of damage
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
YesDid you check under the fuse box? You will have to unbolt it.
