1bad442
I got my Simmons skis and am planning on putting them on this weekend prior to my first ride on my GT. Since the sled is brand new, is it OK to just bolt them on? Do I need to worry about their alignment since the sled is brand new and has never been used? How easy is it to install them as I have never done this before? It looks like one bolt through each ski. Also, where is a safe place to jack up the sled from the front?
Thanks for the help. Can't wait to ride after reading all of your reports. Sort of expecting to shred those wheels though. Maybe I got part of the good batch. PowerMadd Handguards going on prior to first ride too.
Steve
Steve
1bad442
How does one change the alignment?
rock
1bad442,
I've had Simmons Skis for several years now and am very happy with them. However, they did wear prematurely on the front part of the carbide. Bergstrom Skegs out of Illinois offers a shim kit to help solve this. It's very simple to install. You can call Scott @ (815) 654-2950. He'll explain all to you and save you a chunk of change over time.
Also, installation is simple if you have the Yamaha mounting kit (which I assume you do). Simply jack up the front and replace. If your sled is an '06 model you'll need a shorter bolt by about an inch as the stock one is too long for the Simmons. Good luck.
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
Measured mine they were out 1/4" front to back.
This could have alot to do with my darting issues?
I hope the hell so.
Ill try what you posted Bounty Hunter. Thanks.
Scott
I hope the hell so.
Scott
Apexaholic said:Measured mine they were out 1/4" front to back.
I hope the hell so.
Scott
My stock ski's DARTED............the Simmons did just a tad........I shimed them about an 1/8 of an inch after I did the alignment.
.....Almost Perfect, I did a weight transfer adjustment on the transfer rods & changed the preload on the front ski's.Then it was near perfect
snomonut
Just to be sure I understand, the Simmon's require your skis to be perfectly aligned?? No toe in or out? I left my stock alignment (about 1/4" off) alone and thought the sled was awesome!
snomonut said:Just to be sure I understand, the Simmon's require your skis to be perfectly aligned?? No toe in or out? I left my stock alignment (about 1/4" off) alone and thought the sled was awesome!
You will NEVER HAVE TOE IN........Most factory set ups R 1/8 TO 1/4 toe out.
Yes Simmons require a Parrallel set up, NO TOE OUT.
Not trying to hijack this thread but is anyone familiar with C&A skis? I just got some outlaws but they came with cat mounts, can I just use the stock rubber mounts on my GT or do I need C&A mounts. Also should I shim them now or wait, do they require any special alignment. One last thing, I see they have two different holes for mounting the handles back to the ski, one obviously pulls up the tip up further than the other, do I want the tips lower or higher? Sorry for all the dumb questions, just new to C&A skis. Thanks guys!!
snoxraceteam
- Dec 9, 2005
skis
We have the stock skis on my attak and simmons on my husbands. My husband is stuck riding my attak until my simmons arrive. There is tremendous difference between the two sleds, the attak with the stock skis darts everywhere, and the attak with the simmons has no darting whatsoever! My husband is hoping that the simmons get here soon so he can have his sled back. Oh and his attak has aftermarket clutching, and I love that too! So he better order that for my sled if he wants his sled back!
