Jehr
- Jan 19, 2014
- Ottawa, Ont
- 2007 Phazer MTX
2018 Sidewinder STX-DX 137
I experienced a ‘jarring’ incident yesterday when my sidewinder hit a powder covered rock on a lake. It was a significant, direct hit to the skid plate. Aside from the aluminum panels being mangled/dented, it did not have any leaks or obvious internal damage. It ran normal for about 10 miles before I noticed it idling high at 2300 when coming to a stop. I shut it off started it and the oil light came on, still high idle, and no codes. Towed it back, same thing this morning and the battery also died. My feeling is that this is going to be major, but I thought I would check with community here for possible hints before I bring it in. Oil is full, no leaks around the filter, etc. Thanks in advance for any comments.
Pstn head
Try pulling the aluminum skid plate back down the best you could, Might be pinching some wires under there ?
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
Possible that the wires below the fuse block are rubbing on the bracket. It's a known problem area. Tie wrap the wires tighter and insulate the bracket so that the wires can't rub.I experienced a ‘jarring’ incident yesterday when my sidewinder hit a powder covered rock on a lake. It was a significant, direct hit to the skid plate. Aside from the aluminum panels being mangled/dented, it did not have any leaks or obvious internal damage. It ran normal for about 10 miles before I noticed it idling high at 2300 when coming to a stop. I shut it off started it and the oil light came on, still high idle, and no codes. Towed it back, same thing this morning and the battery also died. My feeling is that this is going to be major, but I thought I would check with community here for possible hints before I bring it in. Oil is full, no leaks around the filter, etc. Thanks in advance for any comments.
Jehr
- Jan 19, 2014
- Ottawa, Ont
- 2007 Phazer MTX
Thanks Pstn Head and Chris. I did a full inspection of all the wiring and found that one of the plugs going into the voltage regulator was out. Hard to believe really that this could happen but I plugged it in, charged the battery and it seem to be running fine. Looking like the Aframe is cracked so something I may need to use my insurance for unfortunately.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
While you are at it, make sure the drive shaft and plastic sprockets are not bent. I had one in here that hit a rock and messed up a plastic drive sprocket as well.
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
I had a similar incident with a Nytro. Insurance totaled it.
Turboflash
- Mar 18, 2019
- Southern MN
X2 KA. I just replaced a bent drive axle in a TCat that had hit a rock embankment. Nothing else bent but driveshaft was out 1/4"+
Pstn head
Ahh man I'm glad we could help, but sucks the A frame cracked.Thanks Pstn Head and Chris. I did a full inspection of all the wiring and found that one of the plugs going into the voltage regulator was out. Hard to believe really that this could happen but I plugged it in, charged the battery and it seem to be running fine. Looking like the Aframe is cracked so something I may need to use my insurance for unfortunately.
