hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Is there going to be one for the brake disc too?
As always, good work! Ill be picking up one as soon as your done with them.
I really don't find the oem rotor protector to be a bad design. Its got a gradual approach angle that allows it to glide over things. Will decide once the chaincase protector is done!
Got my samples back yesterday and fit them up. Other than moving a few holes I think its pretty much finalized. Going to go with 1/8" 6061 as the oem protector will remain in place. The approach angle on the protector is a nice smooth transition with no snag points. Very solid piece once bolted in place! Did my fit up on the sidewinder and then jumped over to a 16 Viper just to be sure its the same. Turns out the viper has a different rivet that interferes and the belly panel contour interferes a bit too. The rivet will need to be ground down and then punched out. I then was able to move the hole in the protector so it aligns with the rivet hole and utilized as one of the mounting holes. The 3rd and 4th pictures show the rivet and panel trimming on the viper. Pictures 1 and 2 show the protector bolted on Sidewinder. Final plate will only have 2 holes on each end.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I'm ordering a batch today. Should have them in about 2 weeks. Retail will be $35. Hardware will be included.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Ill be ordering one today! Ill give you a call as I need a couple other items.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
both look great....I'll take a black or blue plate and the protector both....let me know....I already have your belt belly pan guard...and it is bar none the best quality and setup for the $$$
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
FOr the sidewinder, what size holes are we drilling? I see nuts on the left side and two screws/bolts on right. Are there nuts on the other side we dont see or are these tapped?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Got 40 of these in stock now. The bolts are M6 so 15/64 drill works. You will have to drill 4 holes to mount the protector on the sidewinder. On the viper you will have to remove one rivet, and then drill the hole out for one of the M6 bolts.
Photos show final piece and also the location of holes from top side.
Retail for bare aluminum protector with mounting hardware is $35
Retail for black powdercoated one is $40. I dropped some off at powdercoater today, and will have them in 1-2 weeks.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Black ones are now in stock. If you want a black one send me PM with your email address and I will send a paypal invoice.
- 14K
- 9K
