Matt Moak
- Aug 16, 2015
- Ingleside
- 2017 Yamaha sidewinder ltx.
im sure there is a post of this already but couldn't find it I have a grizz gusset kit already installed just wondering if I could still install a full length skid plate from mountain tech, not sure how it mounts in the front. Thanks guys and keep up all the great posts and replies.
Vandelay Industries
- Apr 8, 2008
- Nashwaak Valley, NB
- 2013 Nytro XTX
last post on page 1
http://www.ty4stroke.com/threads/grizz-gusset.125502/
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
you have a few options to mount the full skid plate.
1) weld nuts to the lower gusset
2) install nutserts in the lower gusset
http://www.harborfreight.com/45-piece-threaded-insert-riveter-kit-1210.html
3) use a hole saw to drill a single hole in the lower gusset similar to the OEM gusset and install speed nuts
4) use a smaller hole saw to drill two holes near the required hole location and install speed nuts.
Matt Moak
- Aug 16, 2015
- Ingleside
Rite on thanks for the fast reply. And by the way grizz your gusset kit is great product already recommended to a few guys out here in eastern Ontario.
Mountaintech
Option #4 is the best way. I am not a fan of the rivnuts shown in option #2. They end up failing eventually, especially if they are aluminum.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Yes rivnuts tend to loosen then its a bitch to get the bolt/screw out. I drilled out the rivnuts and went with u-nuts/speednuts and have had no issues since.
Pete
Pete
Mountaintech
Pete
Yup, the internal threads on the aluminum rivnuts are notorious for stripping. They will also start to spin in the holes they're set into. The metal rivnuts are a little better but the tool to set them is expensive and they can still fail eventually. U nuts are the way to go.
Matt Moak
- Aug 16, 2015
- Ingleside
Thanks for the feedback, I already ordered the full length skid plate last nite. Finally got some snow and went for the first test ride tonite and holy F### Iam going to have some fun with this sled, the sound, the torque anyways you guys know all about it. Thanks againYup, the internal threads on the aluminum rivnuts are notorious for stripping. They will also start to spin in the holes they're set into. The metal rivnuts are a little better but the tool to set them is expensive and they can still fail eventually. U nuts are the way to go.
Mountaintech
Isn't the bottom end torque a huge change from the 2 strokes?!!
Matt Moak
- Aug 16, 2015
- Ingleside
Ya for sure there's not enough snow to really see what it's like on the trail,but I was really surprised when I got on the side of the road (snow covered) and squeezed it and how fast it got to top speed. Was kinda surprised it topped out at 159kms not that I need to go any faster.Isn't the bottom end torque a huge change from the 2 strokes?!!
