BlueRider17
In the process of installing my concept front end. Has anyone had an issue with the upper a-arms being stiff when they are torqued in?
The lower arms fall under their own weight, but the upper arms take a bit of force to move up and down. The upper arms move freely right up until I torque to bolts. I should mention that I swapped out the plastic bushings for oilites.
judger101
i have the same thing, i believe i read somewhere that the oilites will loosen up after some break-in
dutchie
mine was snug also , i just put lots of red loctite and snuged them as tight as i could get them to go
this has me puzzeled
what year is your sled , i have a 2010 mtx and i never seen any plastic bushing on my install of the skinz A- arms , inside my A- arms was a long alumn bushing for the top and 2 short ones on the bottom arm , if i remember correctly
did they change them out or did i miss something when i did my install , i sure as heck hope not , hate to have to rip it apart again
someone tell me whats up
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
The long bushing you speak of rides inside of the plastic delrin bushing.
dutchie
Got"ca ya
I never even looked at them , i should of changed them out at the same time , oh well , wonder how long I'll get by befor they wear out ,
