beamer
2007 Apex stopped on trail flashing 22 code and dash lights flashing. Sed would not start and had no spark. Any ideas? Towed 38 miles back to trailer.
spddmon
code 22 is for the intake temp sensor check the conections and wires, or it could be a bad sensor
beamer
Thanks,I looked up the code when I got home and it says it should still run.At least thats a good place to start.
Thanks for the help!
The Artist
Did the battery go dead ?
kinger
Fuel pump fuse next to the battery, do you have the stock fuel pump in there?
Mine blew and it did trhe exact same thing but I had a aftermarket fuel pump to cause mine.
beamer
The Battery failed last week and replaced it. Not sure but it cranks fine just no spark. It is the stock fuel pump and is getting gas. Not sure what to think it acts like a short or ground fault.
07 yamaha attack
- Feb 12, 2021
- Chesterfield
- 07 Yamaha apex attack 1000
Ecu? Mine having the same issue I brought my ecu to shop and put it in another sled it was reading same codes. When I plugged into a different sled. Wasn’t able to try starting it. Since the sled in shop had burned ground block. If you Havnt checked the ground blocks start there
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Check out drive axle bearing. Speedo side, if it tears into speed sensor my engine quit. No codes at all on dash
07 yamaha attack
- Feb 12, 2021
- Chesterfield
Checked it even cleaned it up,
12 14 83 85 I think for codes just pulled harness. Pretty sure that’s where issues is.
no fuel or even power to the pump Or it’s the ecu I think not sending signal is all I can think.
sled still has no Spark. no fuel either that eliminates the stator as the pick up co
