Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
humm never thought of that. I'll try anything at this point.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Mitch hope you get it figured out soon!!!! Give it time here on this site there is a tonne of smart guys that will help you figure it out!
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Are there any temp or oil indicators displayed on the gauge before it shuts down?
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Or is the level just low enough that its sloshing and causing a low oil condition for just enough time to shut it down? All battery connections good under the seat? Just spit balling..
Could fuel tank vent be kinked?
- Apr 14, 2003
- Hessel, Michigan
Lots of good ideas guys
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
Look forward to seeing the solution. Hopefully this issue will be fixed in no time with the amazing wealth of information form the people here. This is why this site rocks!
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
No warning lights when shutting down.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
page 48 in the service manual has 15 possible causes in troubleshooting section "engine shuts down" did you run threw them
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
I don't have a service manual.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Any electrical modifications on this sled? Fuse box relocated, programer, etc?
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
Completely bone stock.
4StrokeAddict
- Apr 13, 2015
- Michigan
Does this only happen while riding or does it happen at idle? Perhaps flick the relays, move every wire and connection etc. Try to induce a failure.
stingray719
Agreed I would pull on all the wiring harness connections.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Could the fuel line be pinched just enough that it dies when you give it throttle and it open enough to Idle??
