martin63092
sled was in heated garage, she ran great before i went away for work, came back instaled yamaha's tunnel closer kit, i then tired to start my sled she is turning fine but wont start then as soon as i stop cranking and i put the key to stop she backfires like CRAZY a big BANG, did this a couple of time and no start. im getting pretty mad its always a problem after another.
spike337
Mine backfired when it had bad gas in it from sitting. Fresh gas, never happened again.
martin63092
she only backfire after i stop the cranking and shut the key off
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Front or rear tunnel?
martin63092
yamahas said:Front or rear tunnel?
rear my friend
- Nov 1, 2009
- 2009 Phazer RTX
martin63092 said:yamahas said:Front or rear tunnel?
rear my friend
I ment hole, front or rear hole of the tunnel lol not front tunnel
martin63092
yamahas said:martin63092 said:yamahas said:Front or rear tunnel?
rear my friend
rear hole
spike337
Rear hole? Doh!
MikeWalters
fresh premium gas and do the plugs.
sounds like a bunch of us had similar problems...
martin63092
MikeWalters said:fresh premium gas and do the plugs.
yes but its fresh premium mixed with a bit of regular from last week and the plugs have maybe 200k's on it
MikeWalters
Wow, sounds like we all need a magic wand in our toolkits for starting our sleds!
martin63092
tomorow i will top her off of gas its maybe 3/4 full now, when i put her in the garage she was full of snow im wondering if maybe water went in the gas when it was melting
martin63092
i had my kill switch pushed in during the week when it was parked, would this had cause a problem or what
No.Be more specific though.Does it click?Fuel pump run?Have you checked fuses and ground block?Are you sure you hooked up the fuel and power to pump or did you not take the exhaust off when you closed tunnel?
spike337
Obviously if you were trying to start it with it off. You would think it would load it up. But i don't know if they'll even turn over with the kill down? I don't think my Yamaha quad will?
