Apps
- Mar 5, 2025
- Verner
- 2024 Sidewinder GT
Is there any way to eliminate the annoying hesitation just off idle? It's like a flat spot when trying to go slow, it's like on again off again. No problem when accelerating.
Don't want to add any tune, perhaps different clutch springs?
Just turned 500 miles on new 2024 sidewinder GT.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
My 2017 did the same thing. I switched to a Dalton Black/Blue in the primary and it is much better but not completely gone. I think you might have to go to one of the soft start springs to eliminate it altogether. It is really annoying though when your clutch engagement is at the exact RPM that you need to go go slowly and maneuver around things.
Yes, you will need a lighter initial rate spring for lower engagement but keep the finish rate equal or you will lose RPM up top of you go to a softer spring all around.
Thinking it's probably not an issue if you're concerned with putting around and having engagement issues.
I have two complete sets of clutches with different calibrations.
One primary and secondary are set up for performance/snow drags and the other set is calibrated for trail riding.
The performance set up is for the 300 tune, engages @ 4500rpm so I can take advantage of launch control, and uses a 8DN belt.
The trail set up favors the 240 tune, engages under 3000 rpm, uses a Gates redline belt and provides quite low cruise RPM on the trail.
I have not had the performance setup on my sled for over 3 seasons now.
Works for Me!
Works for Me!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
You could try the next spring up in the Yamaha primary Spring chart, it's the BL BR BL. it offers a bit lower engagement with a bit more Top End RPM !Is there any way to eliminate the annoying hesitation just off idle? It's like a flat spot when trying to go slow, it's like on again off again. No problem when accelerating.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
Ck the throttle cable adjustment, easy to adjust too.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have some OEM primary springs at home that I got with a group of other clutch parts that I bought locally. I think a couple of them are even new. If you can determine what spring you are after, let me know and I will check if I have it.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Which one is the stock spring? (sorry, I haven't looked it up)You could try the next spring up in the Yamaha primary Spring chart, it's the BL BR BL. it offers a bit lower engagement with a bit more Top End RPM ! View attachment 178367
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Bottom one on the page attachment, Gold Red Gold.Which one is the stock spring? (sorry, I haven't looked it up)
Fast
- Sep 25, 2018
Run the 2019 srx stock clutch set up its perfect no hesitation anywhere,just run the secondary in the third holeIs there any way to eliminate the annoying hesitation just off idle? It's like a flat spot when trying to go slow, it's like on again off again. No problem when accelerating.
