PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Yes! Anti-seized every bolt, and probably every finger...
haha messy stuff! Expensive too! Nice work. definitely a pain in the #*$&@. been there!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Buy Motorcraft nickle antiseize from the Ford dealer. It like $9 a container.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
View attachment 157881 I can’t find nickel antiseize but I did find copper and it’s good for 2000. Will this be ok
100%
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have said it before and I'll say it again. I take those grade 2 ,hardware store, torx headed, junk #*$&@ chain case cover bolts and toss them the first time I remove the cover. Go get some 10mm headed bolts, 6mm x 1.0, about 1 1/2 long. Makes for easier installation as you can then use a magnetic socket to start the bolts.torque spec on the chaincase cover I feel is also to high at 12ft lbs. Twisted one bolt right off
Some here disagree but why put junk parts back in when you have them in your hand and good bolts are cheap?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Change them every year, and use anti seize. I prefer the Nickle but copper will work for sure. Also don't be alarmed if you get a little smoke when you first start your sled after putting new bolts in and anti seize. I have noticed mine smoke SLIGHTLY on first start up. Thinking its the anti seize smoking slightly
These threaded holes in the turbo are actually not tapped very well from brand new. I've had some sleds with under 1000kms where the bolts don't come very well. Run a tap through helps, but being very careful not to break it off in there.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I have tried the Walters ceramic, Permatex aluminum, Permatex nickel and Permatex copper. IMO the copper is the best, I wasn't impressed with the nickel and the ceramic actually froze the bolts in there almost like throwing lime dust into the threads and and baking it in. I now mix the copper with aluminum only because my copper has dried up so badly. You'll be good with the copper.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Thanks everybody copper it is
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Now that you've had them out you won't have anymore issues most likely.... I use copper AS as well, no broken bolts since 2017...
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Thank you gentleman for making this job easy. I was nervous to tackle the bolts but i said screw it and did it anyway. I cut a t50 in half and used a 5/16 wrench to get the 2 hard ones out. I put copper anti-seize on the bolts and put them back in at 15lbs. While it was apart i checked the chain adjuster bolt and mine was good. Broke it loose and it went in about 1 1/2 turn so i backed it back out where it was and locked it down.
You guys are very helpful this site rocks .
You guys are very helpful this site rocks .Similar threads
