MRFUSION
- May 19, 2008
- Peace River Alberta
- 2011 Custom Built Nypex
2008 Custom Union Bay 980 MM Chassis
Hi there guys, been running my Nypex for 2 years now with great success and I will be looking to upgrade my fuel system for next season. I have been running the Boondocker box with good results but looking to go stand alone or an aux injector style system. I run about 16 psi on my Apex engine which is probably maxing out my stock regulator and injectors, I run a little lean it seems on long pulls. I run Daves Meth system and he modified my stock injectors slightly for more flow. Runs clean but looking for improvement. Any suggestions, Boost it, Impulse or anything for more mountain running? Thanx guys. Shad
HYFLYR
Im not sure why anyone wouldnt run the boost it system at this point. It gives you full control of fuel ratios, super clean bottom end, and great guy to deal with.
Iceman56
Why not the complete V1 standalone from Impulse?? get rid of all the stock wiring and other junk you don't need and have a closed loop standalone.
kinger
Mbarryracing has a motec unit he is trying out, I would look hard at that if I really wanted a stand alone.
The boost it is fuel only not really engine management. With your modified injectors I would think you would need to go back to stock injectors, and no fuel box, then add boost it. For that kind of money though what you got is just as good.
Go standalone to get timing mods, closed loop, etc. TWINTURBO at GNS out of chicago has a tec3 system I think that is comparable to motec be worth a look.
http://www.powerbygns.com/Products.html
tjc
how would the motec and tec3 hold up to being buried in powder?
MRFUSION
- May 19, 2008
I talked to Paul at Impulse earlier this year and he said to check with him this summer after more testing. Not to familiar with the Motec system.
Iceman56
MRFUSION said:I talked to Paul at Impulse earlier this year and he said to check with him this summer after more testing. Not to familiar with the Motec system.
What was Paul testing?
MRFUSION
- May 19, 2008
He was working with his V1 system and it is working great on his system but just to make sure it works on other setups. Thought I would hit him up before fall.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
The MoTeC standalone ECU is a waterproof marine model for PWC's / watercraft and the harness has OEM weatherpak style sealed connectors.
MRFUSION
- May 19, 2008
How user friendly is the Motec system, not very familiar with it. Where can a guy research it? I would consider any system that might work in my application. Thanx Shad
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
tjc
be prepared to be impressed, just a bit pricey
Here is a video that shows the MoTeC M400 ECU in a marine application: 100% waterproof -- Motec M400 Marine ECU
All MoTeC snowmobile products are available through Precision Sports
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
What do you think about hooking up the BD box to auxiliary injectors and letting main injectors do all off boost fueling?
It's something i will try next season!
bottlerocket
Is OSPs stand alone water proof?
