allyammies
What is happening here binding something else stuck ?I only top out at 92.
johnnysnowking
Love the Milwaukee's Beast! Yes I meant to say Beast! I can't get my SW over 95ish and I have the LTX-le 137.
Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
Are you using a clutch kit? What belt are you running?
allyammies
Ulmrrs kit and 8dn. Run 9050 on top end. Just looking at the belt dust something may not be right.
johnnysnowking
I took it back to my dealer and they said they needed to shim out the clutch and it isn't a warranty issue. So out of pocket it is.
Vilas
- Sep 6, 2014
- Urbana, Illinois
Belt deflection set properly with the belt ribs just peeking out over the top of the secondary?
allyammies
Yes sir. They dont call it the best for no reason!
allyammies
6 n 2 on the secondary wrap.
johnnysnowking
This is where mine sits. Not good
Vilas
- Sep 6, 2014
- Urbana, Illinois
Shoot you need to get that baby up higher. Get one of those secondary adjusters. I did and it solved a bunch of issues. 89 bucks from thunder products. I also got a gates carbon fiber belt and the pair made things better. Here is the link:
https://thunderproducts.com/shop/yamaha-secondary-clutch-belt-adjuster/
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Your belt is slipping in the secondary, indicated by that black line. What does your primary look like?
allyammies
Nothing on the primary.
rbell14
Even with adjuster, after I run mine it rides about that high and was set with ribs on belt just above secondary. I have a 6-2 wrap.
rbell14
What's the root cause of belt slippage on secondary? Worn belt?
I get the primary and with weight adjustments you can dial in grip don't know what adjustments you can make on secondary other than setting proper deflection.
johnnysnowking
