Dan_SRViper
- Feb 11, 2019
- New-Brunswick
- 2014 Yamaha SR Viper XTX
So I've change the chaincase fluid from my 14 Viper, and not really sure if I put the shaft back in correctly or not. I've tested reverse once in the garage and it worked. When for a test run put it in reverse and I was not able to put it in forward again, just stuck in reverse. So I took the actuator apart and the shaft was out of the bottom slot, I was able to put it back forward by hand... Is it me putting the actuator back wrong, or is something else wrong?
Thanks!
Thanks!
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
I think you're having the same problem as I once had. Check this out.
https://ty4stroke.com/threads/adding-chain-case-fluid-tutorial-56k-warning.123842/
