Reverse
I've got an 05 Vector that has had the clutch upgrade but still sounds like a 29 Ford rolling along. I had some additional work done on the secondary which the dealer says was necessary because I didn't blow out the secondary once a season with compressed air. Anyway any advice???Should I just throw the whole stock thing out and put an aftermarket???
Reverse
Anybody...????
DoktorC
just the idle rattle? or something worse?
Reverse
Performance seems OK; yup just the ratttle at idle and maybe 200 -300 RPM past idle when accelerating; but a BAD rattle
Grimm
I say take it back to the Dealer as they may not have done the job right. How long ago did they do this work?
Reverse
The dealer (reputable over the years)did the work about a month ago; was a little quieter; told me that's the way the cutches sound. I've heard others some quieter, some about the same....mostly looking for a "quiet" solution. Appreciate your input so far and continued
VT_BluYamaha54
- Dec 20, 2003
- Vermont
- 2012 Vector LTX
2004 RX-! Warrior
1984 Phazer (Antique)
There are a couple of things you need to be sure were done by the dealer for the '05 "Clutch update". Review this thread:
http://www.ty4stroke.com/viewtopic.php?t=36796&highlight=clutch
Reverse
Blu: Thanks a lot; that info you passed on really helped
VT_BluYamaha54
- Dec 20, 2003
- Vermont
- 2012 Vector LTX
2004 RX-! Warrior
No Problem. I pass credit to Rex.
We ride the best sleds in the World
This is THE BEST Yamaha Specific site in the World.
And some of the BEST PEOPLE hang out here to help each other!!
Reverse
The guys on the RS thread say that putting washers on the both ends of the bolt that holds the pins works; and that the washers could be made of rubber, nylon or even leather. Any body see any potential problems in doing this; another guy said that his dealer said that slack was required.
