1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
9K!! wow . don't wait so long next time?
The old ones look good yet. I almost regapped them and put back in. I gapped the new ones to .020" and installed those since I had them.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
LOL.. I remember riding with someone from this site two years ago and I Had about 5-6 K on my plugs.. And he was like "change your plugs" I do them every year.. You should also!The old ones look good yet. I almost regapped them and put back in. I gapped the new ones to .020" and installed those since I had them.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Anyone else foul a plug?
mario750
- Jan 14, 2018
- New York
- LTX SE - sold.
230 miles I’ve made it on new set before I have to replace them.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
What you running for boost? Using high amounts of octane boost? Gaped to 0.20" ... Something is wrong if your burning plugs in 230 miles..
mario750
- Jan 14, 2018
- New York
- LTX SE - sold.
Mainly 240 SS on 90-91 octane non ethanol fuel . I do carry a motorcycle size Lucas booster but I’m not adding it on every fill up .
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I don't know. But that is not good if your only getting 230 miles.. Just not hearing issues with plugs, I could see maybe running up over 300 HP. But where your at you should be able to get 5K out of your plugs easy.. I change every year, never had plug issues in 12k miles
mario750
- Jan 14, 2018
- New York
- LTX SE - sold.
I mean that’s happened first time when new set didn’t last a full season of riding.
SledFreak
- Feb 7, 2005
- Ontario. Canada
I am still confused mine went as well. Mine was stock when it started acting up at 230 miles. Even from brand new, It was Not starting well and would sometimes take a couple of tries, mainly first start of the day where it was in my garage or sometimes when I was riding and I stopped. Where it went worse, was I loaded my sled from the garage to my trailer for the night because I was going to get a tune installed, so I had to travel a couple of hrs.... That morning it was cold (-15C) when I went to move it from the trailer to the garage, it only fired on 2 cyl for about 2 minutes, then the 3rd kicked in after. Took it for a short rip to clear it out and all was good. But, since that day (about 100 Miles later) it seems to have gotten worse where I have a low stumble below 5000RPM and then it just takes off, so I know one of the plugs are done. I am chalking it up to a bad plug from the factory. I will pick some up this weekend and see how it works after that. Snow is gone, so I am hoping its not going to be an issue. I always wait until it gets to 160-165 degrees before I move it. Having said this, My 2009 Nytro XTX snuffed 2 plugs on me.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Possible the valves are slightly off (too tight?)on some motors right from factory? These motors are damn good but ANY manufacture has a few that go out, that are out of spec(valves).. I know for a fact this was the case on the Vipers.. Caused issues with starting..
Think how many winder motors have been sold and how many on here have issues.. Id say they are damn good motors.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
What’s the reasoning for going .020 on plugs?The old ones look good yet. I almost regapped them and put back in. I gapped the new ones to .020" and installed those since I had them.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The tuners say to go with that spark plug gap for the higher boost pressure.
SideHogger
- Apr 16, 2016
- upstate ny
Looks like I’ll be pulling plugs today.....lol. Too bad snow is going.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
"Plug gap .020 for trail .017 for boost higher than 25 psi." Straight off of TD website
Turboflash
- Mar 18, 2019
- Southern MN
At higher boost levels (17+) there is allot more cylinder pressure than stock. That higher cylinder pressure actually tends to suppress the spark. So, to make sure the fire gets lit and ignition is consistent, a smaller gap makes it easier for spark to jump the gap.What’s the reasoning for going .020 on plugs?
