Benwaballs
why don't all you cry babies just wait and see what people say about them! I am stoked I have a love hate relationship with my nytro but I sure do love that motor!
YamBam
Lets not forget all of the changes from the 2008 to the 2009 Nitro and how much better the 2009 handled. Still want a first year Viper with all that Cat quality?
YamBam
fxnytro1050
my nytro on weight scales, full tank of gas ready to go with small mods listed below was between 610-620 lbs. scale rounds to nearest 10.
fxnytro1050
sledhead23
Schlorven's posted a site in the general 2014 thread that has the weight it is claiming 219kg or 483lbs. Thats pretty good weight loss, 25lbs actually. Heres a quick comparison.
Doo MXZx 1200 Vs Viper SE: 499 - 483 = 16lbs
Doo MXZx 600 Vs Viper SE: 462 - 483 = -19lbs
Doo MXZx 800r Vs Viper SE: 472 - 483 = -11lbs
Doo MXZx-rs Vs Viper SE: 458 - 483 = -25lbs
AC F-1100 snopro Vs Viper SE: 518 - 483 = 35lbs
AC F-800 snopro Vs Viper SE: 454 - 483 = -29lbs
Poo 600 rush pro-r Vs Viper SE: 464 - 483 = -19lbs
Poo 800 rush pro-r Vs Viper SE: 464 - 483 = -19lbs
Nytro RTX Vs Viper SE : 508 - 483 = 25lbs
all these numbers come from published dry weights. If this is true it shows 4 strokes can be fairly competitive with weight.
http://www.finn.no/finn/mc/snowmobile/o ... RONT_CLICK
sledhead23
Also if the AC video about snow build up is actual (http://www.youtube.com/watch?feature=pl ... YXyOL3hxM#!) and the PC chassis does hold 36lbs to 47lbs less snow than the competitors, This combination may be the first 4stroke to be the same weight or lighter then competitors 2srokes in real world riding environments.
NFLD-Nytro
SteelerJim said:People complain about the weight of the Nytro. It wasn't heavy in 2008 and still isn't by 4 stroke standards. In fact I think the only 4 stroke in the Nytro's engine class that's noticably lighter is the doo 4 tek. Everything else weighs about the same as a Nytro
You're on crack if you think the Nytro is not heavy. It's a big brute that wears you out if you're riding in deep snow or rough conditions.
I don't know if the Viper will be any lighter, but let's not get foolish trying to convince ourselves that the Nytro is some kind of lightweight. It's not.
sledhead23
SteelerJim is right though about the weights with the 2013 sleds, the nytro has lost a considerable amount of weight since 2008. The 1200 mxzx is 499lbs and the nytro rtx is 508lbs so not a huge difference. With the nytro on the other hand it feels heavier because of the front end geometry and motor placement. This goes to show you that its not all about weight but where that weight is situated and thats what the viper addresses.
srx700lt
My Nytro XTX is 274Kg, that would be 604lbs.
SteelerJim
srx700lt said:My Nytro XTX is 274Kg, that would be 604lbs.
That's a wet weight. We were talking dry weight
Dano
The Viper shouldn't have a 20-30 lbs block of ice under tunnel. That in itself is good enough for me. 40L tank of fuel? I'll take that wet weight thankyou. Its about time...thanks yamaha
Dan
Dan
SteelerJim
NFLD-Nytro said:SteelerJim said:People complain about the weight of the Nytro. It wasn't heavy in 2008 and still isn't by 4 stroke standards. In fact I think the only 4 stroke in the Nytro's engine class that's noticably lighter is the doo 4 tek. Everything else weighs about the same as a Nytro
I've never done crack
This is what I've heard, the Viper is 467 lbs bone dry. No fluids anywhere, not even in the shocks. 145 hp. It is supposed to be substantially lighter than a Nytro.
We'll have to see what the specs are when they are released.
- 48K
