Spindle Fix
Jeffz
Cresco, Iowa
2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
After breaking both spindles on different rides last year, I'm down to my last good set of back-ups. Now the top hole in the right side is egged out from not using Loc-tite and improperly torquing the bolt. It also wore into the top of the spindle. Here is my fix for this problem. I first milled the hole to .625" to clean everything up. Then cut a pocket .090" deep at .875" dia. Then made an aluminum block that fits snuggly in the top section of the spindle itself, then drilled and tapped a hole in it for the upper ball-joint bolt. I then made a steel flanged washer to fit in the hole and pocket I cut so the ball-joint had a hard surface to contact. The other spindle is not damaged so I'll skip making another one. The reason I went with the large aluminum "nut" is because I was going to make the flanged washer long enough to go through it, then use a longer bolt and put the stock nut below the next section of spindle. I figured this would be quicker and easier. We'll see how it holds up this season.
