NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
I picked up a set of split rail skis and am wondering if there is anything special I need to know for the install, looks pretty straight forward but they are telling me I will need some special Yamaha washers, where do these go and will another washer work in it's place?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
It was some time ago I installed mine, but the kit was pretty complete. It did not require additional parts. Their diagram was pretty clear indicating where the new split rail washers go and the existing washers.
Let me know what you are referring to, or send a pic.
Ms
Ms
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
I basically bought these bare, they came off a 09 nytro split rail said I need to use Yamaha washer 9002-1052 just not sure where to use them.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
would those be the washers used to shim the ski stance?
yamakazie
What year Nytro are you installing them on? I believe the 08's and 09's require different washers on the ball joint attachment to the spindle. My 09 has a washer above and below the lower ball joint and one below the user joint.
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
I am installing them on my 08
yamakazie
You may not need the washers then. You'll know when you install the lower A-arm
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
srxpert
The washers they are talking about are used at the tie rod ends. When you remove your spindle save those two washers and reuse.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Do you have the schematic from split rail.?
Ms
Ms
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
No these where bought used, they sent me some directions but it doesn't show a schematic, do you have one you can post?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Can't post it right now. Have to wait to get to the office to scan it in etc. Pm me your email, I have just taken a pic and will email it to you.
Ms
Ms
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
sent you a pm
- 48K
