sideshowBob
I just completed spring maintenance on my SW and put the sled away ready to ride next winter. Feels good to have it all done.
I had most of the sled dismantled to check bearings, bushings, hoses, clamps, wiring ect ect.
I was amazed at how good every thing looked and never found anything that really needed immediate replacement.
As well as normal maintenance I did some upgrades some of them that I had been putting off for the last few years.
-BOP auxilary rad/fan kit
-Dasa racing billet water pump impellar
-adjustable fuel pressure regulator
-DMC top gear bushing
-2022+ updated drive shaft installed with both BOP shaft saver and bearing
-PEFI chain case adjuster
-ect ect
-ect ect
Nice work!! Feels good to have it done?I just completed spring maintenance on my SW and put the sled away ready to ride next winter. Feels good to have it all done.
-ect ect
View attachment 172602View attachment 172603View attachment 172604View attachment 172605View attachment 172606
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Awesome! Now I'm jealous!!!
sideshowBob
Yes for sure...now time to work on the boats...LOL...it never endsNice work!! Feels good to have it done?
northern srx
I see Klotz 2 stoke oil...!!!
sideshowBob
LOL...I still use it in my Wife's Vmax and my chainsaws ect.I see Klotz 2 stoke oil...!!!
kinger
How many miles on it? I am doing the same thing on BOB and the orange flame this summer but you are much faster
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Bob nice work. will you come do mine for me?
I have had some medical issues and am not able to work on my sleds yet.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Nice work! I started last weekend with my groups sleds. Dropped suspensions and removed front shocks from 6 sleds. My shocks from the Sidewinder and Viper are in Cannondales hands currently for service. Then removed a bad heat exchanger out of my nephews 14 Viper. So it's a start!
stgdz
- Mar 27, 2021
- Buffalo MN
Dropped shocks off at rebuilder last night. He's four weeks out! Normally two.
I've gotten most of my jobs done, split the caliper and got all the nasty disgusting crud out. Spent the 20 mins bleeding the caliper and then decided I may want to check the drive shaft bearing.
One roller had some rust on it. Awesome. Have to pull all that stuff out again and pull the bearing. 5700 miles and replacing it with an skf.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
-ect ect
What kind of instructions did the water pump impeller come with (I'd be curious about getting a copy to see what the job entailed)?
Looks good Bob! Definitely getting me in the mood to start turning wrenches and tackling the bigger projects I have in mind for my SideWinder!
sideshowBob
The impeller did not come with any instructions. I searched on the forum and found some good tips on the steps required.What kind of instructions did the water pump impeller come with (I'd be curious about getting a copy to see what the job entailed)?
for example:
Water pump failure
2017 LTX LE - out at the lake Sunday, did some easy miles to break in a new belt. Did a few pulls on the lake, and immediately after getting off the gas on my last pull the engine temps went through the roof. I let it cool down for 20 or so and then tried to get it back to the cabin but no luck...
ty4stroke.com
sideshowBob
After doing all the spring maintenance/improvements on my SW I never had a chance to ride it as the season was over. I rolled the sleds out this past week and got a chance to run the SW after the BOP auxiliary rad install.
Fortunately no leaks!
We have very little snow on our property, just enough to drive the sled on and temperature is right around freezing. With very little snow for cooling[1 3/4" track], no scratchers, slow riding and intentional idling the sled never went above 180F. The aux fan included in the kit cut in @ 180 and the sled stayed at that temp for the time I idled it. In the past the sled would have gone into limp mode under the same conditions.
Its all good!
Its all good!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Its all good!
Good to hear!
- 39K
