sproket slip! what is the best sproket?
alexyamrx1
Pont Rouge Quebec
I guys! I run a apex mountain MPI stage 1,my drivers slip all the time??? i put NEW (WAHL) Anti Ratchet Drivers! and after some ride it slip again!any body have solution for my? my track is very tight and slip yet! my track is 159x15x2.25 / 2.52 pitch my suspention is a ZX2 AD BOIVIN! with (WAHL) Anti Ratchet Drivers 9 tooth 2.52 pitch thanks guys
If you need 8 tooth 2.52 pitch drivers you'll have to stay with the Wahls. Avid doesn't make them.
Ken.........
Please add your location to your site profile, thanks!
If you're only running a stage1 and slipping your drivers, I'm wondering if you have something else going on with your rear suspension that would cause that to happen so quickly? I don't know much of anything about the ZX2, but I wouldn't think that the power level of a stage1 would do that?
Maybe I'm wrong, but does that sound strange to anyone else?
I had this problem with my zx2...the fix was to tighten the track so there is a 1" sag.
At outside temp.
Or if you store in a heated garage at 72 degrees there would be zero sag.
I haven't had the problem since and I run stock drivers and 10 lbs boost.
