slowride06er
Starter is making noise hope its just the starter. It makes noise while cranking and did start the sled for two days. I did some reaserch should I be replacing start relay as well. I'm installing a used starter today
slowride06er
Starter is in and its working as it should. After I removed old one I found excessive amount of play on the shaft compared to the one I installed. I'm going to ride tomorrow for the day I will keep you posted if it acts up again hopefully I don't have another problem that was over looked
sideshowBob
How many miles are on the sled?
slowride06er
Sled had 9200 when I pulled starter
