Hi guys I have a question here that maybe somebody can answer. My starter has made some funny noises the last couple rides, I think I may have cranked it too long. Anyway it starts fine but today I was cleaning the clutches and rotated the primary backward and I heard a grinding noise and felt some vibration. I dont have time to take it all apart right now so I am looking for ideas. If I rotate the clutch forward it makes no noise or vibration. Could it be stuck in the engaged position? Thanks for any help.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
never rotate these engines backwards. It can cause internal damage.
pulled the starter today. Its toast, clutch looks good.
royal distributing $ 212.00 for a starter.
erosled
1) What you heard was normal. Spinning the engine backwards engages the starter via the one-way clutch.
2) Rotating the engine backwards will NOT cause any problems.
nards444
Had this issue on a 06 nytro and the starter ended up going. New ones are espenive and redicuously priced. look for a new used one or see if somebody can rebuild it
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
erosled said:1) What you heard was normal. Spinning the engine backwards engages the starter via the one-way clutch.
Rotating the engine backwards can cause problems.
http://www.ty4stroke.com/viewtopic.php? ... +backwards
