YamahaHoss
- Mar 23, 2020
- Wisconsin
- Yamaha RS Venture
Thanks, I am alittle froggy on where that relay is on my 2025 RS Venture TF. Is there any partzilla type drawings where you could point me to which wore that is please?The led lamp hot wire goes to the starter relay on top of the oil tank. The ground wire I have always attached to the steering post. The idea is if the light stays on after starting the engine you have a stater relay stuck in the on position and you starter will stay engaged. Things will go bad quickly if that happens.
JustJoe
- Dec 4, 2023
- Connecticut
- 2008 Yamaha Nytro FX
Looks like the left side of the battery tray which is likely under the airbox and suchThanks, I am alittle froggy on where that relay is on my 2025 RS Venture TF. Is there any partzilla type drawings where you could point me to which wore that is please?
