rx1mtn
Looks like I'm going to have to change the starter on my 2014 SR Viper. Can the starter come out without engine removal? The starter draws over 125 amps and there isn't any engagement, can't hear the starter do anything. TIA
rx1mtn
Well... the answer is yes. Found the the problem too. Broken magnets in the main body.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Common issue, unfortunately. I hear you can change it through the same access panel as oil change?
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
I replaced my starter a few weeks ago. It's not extremely easy but can be done through the bottom panel opening. You need to remove the oil filter and then remove 2 bolts that hold the starter on as well as the starter cable. You don't need to drain the oil pan as some others have suggested.Common issue, unfortunately. I hear you can change it through the same access panel as oil change?
rx1mtn
Yes, through the bottom cover. Tight quarters, but I did get it out. I was concerned, I don't have a shop manual for the Viper, but I do have 1 for my NYTRO XTX, and that shows that the engine has to bee removed 1st. Disassembled the starter and found the magnets broken. I have been having starting problems all year, I'm glad it happened while doing a "skid" rebuild for next year and not somewhere out in the mountains.
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
What are the symptoms of the starter going bad other than the normal things like grinding, won't engage etc.
Yamasledder
- Mar 7, 2010
- 2020 Viper LTX SE
With mine, it turned the engine over slower than it should even with a fully charged new battery. The last time it started the engine before it quit working completely, it turned the engine over faster than I had ever heard it crank. Then on the next startup, it wouldn't do anything. Just a click from the relay and it was a dead short circuit. When I took the starter off, the magnets were not broken but the glue that holds them in place had let go and the magnets were all grouped on one side of the starter housing.What are the symptoms of the starter going bad other than the normal things like grinding, won't engage etc.
The replacement starter that I bought from eBay is an aftermarket and is much cheaper and also cranks the engine over faster than I've ever heard it crank in the past.
Yamasledder
- Mar 7, 2010
- 2020 Viper LTX SE
I just noticed that you're from Canada. Royal Distributing has a competitive price on these aftermarket starters as well.
rx1mtn
With mine, it would just click, like a low battery. In fact, I almost changed the battery before I headed west. When it finally went bad, I had just rebuilt the skid and had it running to make adjustments. I shut it down, to check all fluid levels when hot. Then when I tried to restart, click is all I heard. This time though, all of the lights and dash about went out when I turned the key, like a major draw. I check the amp draw and it was over 170 draw when trying to start. Thats when I knew it was the starter.
brother put one on an 09 phazer from royal and it only made it just past warentee before it started failing again. put a new oe one it it becasue of that.
maine sledder2017
- Jan 17, 2017
- maine
- 2012 rs venture gt
think my 2012 venture has same issues.............. wow looks tight underneigh..it sitts up behind the motor ..... under the exqaust... wonder if mine can be done as well ..............Looks like I'm going to have to change the starter on my 2014 SR Viper. Can the starter come out without engine removal? The starter draws over 125 amps and there isn't any engagement, can't hear the starter do anything. TIA
RAMSOMAIR
With the Venture, I had to pull the exhaust back and donuts out. Then tip the motor forward and then there was access.
