Viper989
- Nov 3, 2019
- Charlevoix MI
- 2014 SR Viper LTX SE
I am new to the snowmobile world and just picked up a 2014 SR Viper LTX with 3,300 miles on it. Changed the oil and chain case oil this weekend, no issues. Machine started well 10 or so times since picking up the sled and checking oil level. Went to start it today and as it fired, I let off the key, heard a bit of a pop, and the machine shut off.
Starter won't turn over now. Checked the solenoid by the battery. Test light lights up when turning the ignition. Checked for power at the starter with a test light from red plug on starter to ground, and test light turns on. Turned the primary clutch about 1/3 turn in direction of running engine and engine seems to turn over just fine.
Is this likely a bad starter that went out? Also, are there any other ways to test the starter itself? From reading it seems like starter can be replaced through oil filter cover, can anybody confirm this?
Thanks in advance!
Thanks in advance!
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
If the starter is getting power but won't turn then a magnetic inside the starter probably broke and locked it up which is common with these. You'll need to pull the starter and replace it. You'll also need to inspect the starter idler gear inside the engine to make sure it didn't brake and drop teeth inside the case. If it did then the stator cover will need to come off. https://ty4stroke.com/threads/starter-gears-and-one-way-clutch-inspection.150516/
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
Also, if you find it’s a problem with a magnet in the starter, it’s a good idea to also replace the solenoid by the battery. They’ve been known to stick on and melt the starter while the engine is running.
Barry
- Mar 11, 2015
- bridgewater
- SR Viper
Just a thought, are you sure its not loaded up. I have 14 xtx, and was always told not to start too many times without letting engine get to full temp and cleaning outI am new to the snowmobile world and just picked up a 2014 SR Viper LTX with 3,300 miles on it. Changed the oil and chain case oil this weekend, no issues. Machine started well 10 or so times since picking up the sled and checking oil level. Went to start it today and as it fired, I let off the key, heard a bit of a pop, and the machine shut off.
Thanks in advance!
